Thread: power steering issues part 2
    Jul 2010
    folkestone
    Default power steering issues part 2
    hi everyone right my power steering problem is a complete mystery now, yesterday i drove through a car wash and it worked ok till i stopped the car on restarting no power steering so i drove a little and it sprung back into life, stopped the car and restarted and it was dead again,
    today i checked the connections for water and wd40 ed them too expell any water and the fluid level which was max the 80 amp fuse by the battery and the fuse f10 (7.5 amp) in the passanger fusebox, the strange thing is i have NO fault warning light on the dash and doing the pedal test i get code 1530 which is aircon clutch malfunction,
    any help would be much appreciated thanks
    Jul 2010
    folkestone
    help please lol
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    Maybe you could check the "vehicle speed sensor", i am sure it is fixed in the n/s/f wheel bearing, check the electrical connections lower shockabsorber. The faster you go the less powersteering you need, also on the steering rack is the steering angle sensor which comunicates constantly with the cim behind the steering wheel "electrical signals for left and right turns and straight ahead, hope this help you....
    Jul 2010
    folkestone
    cheers omega63 the speed sensor is still working as the traction control still operates its really got me stumped this one the angle sensor is worth a look as u say the strange thing is no fault on the dash warning system the light isnt on and re checked codes tonight and all i get is 1530 air con clutch circuit malfunction
    May 2011
    surrey uk
    strange thing this is what happened to me , just came out of car wash and 1 mile down road car cut out and no power steering , , also after £1100 at vauxhall dealer after 1 month they still cant rectify the fault am totally stumped
    anybody else know the layout for the fuse relays , want to change the relay for powersteering but cant find list anywhere
  1. Power Steering Issues, Solved
    By jatint in forum Engine & Drivetrain
    Last Post: 10th August 2013, 17:38
  2. signum z19dth power steering issues
    By paulyboy in forum Engine & Drivetrain
    Last Post: 12th December 2012, 19:16
  3. Replies: 6
    Last Post: 9th December 2012, 18:40
  4. Power Steering Issues - 3.0 v6 cdti
    By larann in forum Engine & Drivetrain
    Last Post: 2nd July 2012, 23:08
  5. Power Steering Pipes Part Numbers
    By M65 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th October 2011, 16:20
