Results 1 to 10 of 19
Thread: timing chain question
    Regular Member TomiboyC's Avatar
    Aug 2007
    East Ayrshire
    Default timing chain question
    been on the phone getting quotes for chain replacement when someone put a spanner in the works by mentioning the secondary chain. can someone explain what this does and if its advisable getting them both done at same time to save on labour costs. (2.2 direct 56 plate).
    ta.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The main chain is the important one and the one that tends to go, its the one that stops the piston hitting the valves LOL. The Second chain works the balancer shafts and is far more robust. How many miles has it done mate? Pop onto the 2.2 forum and mention it over there.
    Aug 2007
    East Ayrshire
    cars done just over 50k mate, aware that the main ones a must to be on safe side just didnt realise there was a second.
    Regular Member Jezzy's Avatar
    S.E
    Does your engine have a problem, or are you just being cautious? If it's the latter, you probably don't need to have the chains replaced - just give the car regular/frequent oil changes and use Mobil1.
    Aug 2007
    East Ayrshire
    bit of a rattle on start up and after reading about problems with the set up and seein as how people are reporting chains slipping and snapping between 40/60k then thought it would be wise to replace. maybe bein a bit cautious but better to be safe than sorry
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    If you have a rattle - get it changed.. Simple.
    VX introduced a new tensioner in approx 2007.
    Not sure if you are local to Benny - but I am sure he wont mind me telling you that he does them privately.. and hes VERY good.
    Aug 2007
    East Ayrshire
    bennys about 4.5/5 hrs away mate even when he comes up north which he's mentioned before, he's still about 4.5 hrs away, my own fault really, did think about it before but kept putting it off, now at stage where its time to do something about it
    Middlesex
    Trim : SRI
    Mileage : 100k
    thats a shame.. What about appy from vvoc - heard of him? VERY good rep on there indeed, and he travels the country doing them.. He did a 3.5 hr drive to me for a fraction of the cost of any garage..
    12 Post(s)
    Quote Originally Posted by TomiboyC View Post
    Then you might get away with just fitting the revised tensioner.
    Aug 2007
    East Ayrshire
    might just pop over have a look, cheers mate
  1. Timing chain
    By dave_scarborough in forum Engine & Drivetrain
    Last Post: 27th April 2012, 22:30
  2. Timing chain
    By signumboy in forum Engine & Drivetrain
    Last Post: 11th August 2011, 18:19
  3. timing chain?
    By adammarc in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2011, 19:54
  4. Timing chain question
    By clive3373 in forum General Chat
    Last Post: 22nd April 2009, 22:11
  5. timing belt/chain question
    By Baldy in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2006, 12:11
