Page 1 of 9 123 ... LastLast
Results 1 to 10 of 83
Thread: Tuning vectra c 3.2 V6
    manchester
    Default Tuning vectra c 3.2 V6
    Hi i have recently bought a 3.2 v6 vectra con a 53 plate, i want to improve the performance on the car but i dont have a clue where to start.
    I have seen i few post on air filters/induction kits etc but to be honest i don't have the slightest clue where to start.
    Any help will be much appreciated i live in Manchester.
    Full Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    33 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    A fine purchase, if I may say! Not that I am biased...
    The usual approach with a 3.2 appears to be something induction-related, such as "the airbox mod" (use the forum search ) and a K&N or similar panel filter, a cone filter (possible heat soak issues) or an enclosed cone filter with cold-air feed. A cat-back exhaust apparently can help improve pick-up and response. Then it's a remap. With those mods, you could be looking at a healthy 235 bhp or so at the flywheel. Not a vast increase but the improved response is worthwhile, I'd guess.
    Mine is still bog stock and is fast enough for my tastes - and then some! But I do have some enhancements in mind...
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    I swear by the K&N Apollo filter. Very, very slight gain, but the sound is amazing. Apart from that it gets pretty pricey. Theres cams, throttle bodies etc. But few have done either as far as I know.
    Go the intake -> exhaust -> remap route.
    Heres how my baby sounds
    WITH Remus:
    http://www.youtube.com/watch?v=YV_upBdedyU
    Without Remus:
    http://www.youtube.com/watch?v=pl6xQ102j8s
    West Yorkshire
    Foam Airfilter has to be the way to go for sound alone.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Quote Originally Posted by Vectra_C_Chris View Post
    WITH Remus:
    Without Remus:
    been looking at cams as im getting a cambelt change. do u know where to get them ive had a look but cant find any. cheers
    Regular Member hagga's Avatar
    kingswinford
    Panel filter+airbox mods or huge foam filter (I've had no heat soak issues), decatted exhaust(emmisions are fine due to pre-cats),Iridium plugs, remap.. mines approx 232-240 at the fly(depending on what calculations you use).. cams will give a lil more by narrowing the power band and rais.ing rev limit will free some up too.. the main issue with 3.2s is that the down pipes/pre cats are restrictive.. as far as i know pre cats can't be removed as sensors either side and ecu says 'no'.. big power gains can only be done by adding decatted downpipes,flowed manifolds and throttle bodies and stand alone ecu.. along with cams/lightening/balancing etc.. and after all that you're still only looking at vxr power... I'd go with the intake/exhaust/remap.. cost you about 700-800 for an extra 20-30 bhp
    Regular Member fuzzbomUK's Avatar
    Milton Keynes
    I went a slightly different route than just going for more power.
    I fitted the 314mm brakes, braided hoses, eibach springs and a strut brace. I then went for a Panel filter, plugs and an exhaust.
    Not sure the engine mods give it more power but it does seem to rev and pull better.
    Personally though the best upgrade i made was improving handling. changing the tyres from 215/50/17 to 225/45/17 also helped on that front. (P6000's instead of cheap ones)
    My rule of thumb is when somthing needs to be replaced upgrade it i have thrown way to much money at cars in the past.
    33 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    Quote Originally Posted by fuzzbomUK View Post
    What does this sentence mean, please? I don't understand.
    Paul
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    I tried a Pipercross Viper closed induction kit on mine and throttle response didn't seem to be the same, so i've stuck with my panel filter and airbox mod.
    As for a remap there has been some threads about bore wash (not sure what they mean by this) so the only way to do this would be a live map.
    Finally i have had an MIJ exhaust fitted and had it de catted whilst there and when the car was put on the rolling road a few months after my horsepower was up by 10 bhp.
    kingswinford
    Quote Originally Posted by Hyperhart View Post
    As for a remap there has been some threads about bore wash (not sure what they mean by this) .
    If its way overfueling you get non atomised fuel washing the oil film off the cylinder wall causing rapid wear.
  1. DNA Tuning Vectra 2.0 Turbo
    By pipamish in forum Petrol Engine related
    Last Post: 5th September 2011, 22:13
  2. PedalBox – Tuning for all Vectra’s
    By coldo in forum Petrol Engine related
    Last Post: 1st July 2011, 13:54
  3. Vectra tuning box fitting help
    By shug176 in forum Diesel Engine related
    Last Post: 20th September 2010, 02:25
  4. astra to vectra tuning box?
    By li4m in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2010, 21:06
  5. MIJ Vectra B DTI tuning
    By Big-Pete in forum Diesel Engine related
    Last Post: 27th July 2008, 12:20
vectra c 3.2 v6 tuning
vectra 3.2 v6 tuning
vectra zc 3.2 dyno grAph
vectra c 3.2 virittäminen
vauxhall vectra c gsi 3.2 engine modifications
vauxhall vectra 3.2 upgrades
vectra c 3.2
vauxhall 3.2
vauxhall 3.2 v6 dyno graphvectra c 3.2 v6 how many were builtvectra c 3.2 coughsvauxhall vectra gsi 3.2 v6 tune up vectra 3.2 v6 induction kitvectra 3.2 tuning3.2 vectra performance upgradesvectra b 3.2 engine modsVectra c 3.2 v6 modsVauxhall vectra v6 tuningvauxhall signum 3.2 v6 tuning exhaustopel 3.2 v6 tuningvectra 3.2 gsi tuningtuning 3.2 v6 vectravauxhall vectra v6 3.2 remapvauxhall vectra c 3.2 v6 air intake modsopel vectra c 3.2 v6 irmscher
