Results 1 to 10 of 20
Thread: Undesirable suspension noise
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    276 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Default Undesirable suspension noise
    Another (hopefully minor!) problem - My Signum has started making what I can describe as a loud creaking noise from the front suspension when passing over speed bumps and humpback bridges. Any ideas? Cheers!
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    arb bushes/drop links
    woodbridge, suffolk
    276 Post(s)
    Trim : Design+
    Mileage : 101000
    Thanks guys, any idea roughly what they cost and are any special tools required?
    Regular Member parttimer1's Avatar
    Dec 2010
    edinburgh
    Easy job and cheap, mine are due and I looked it up. Mine get quieter once warmed up but a very noticable 'creak' when cold. Doign them in a couple of weeks when my HIDS turn up.
    Quote Originally Posted by littleteapot View Post
    anti roll bar bushes - approx £3 each from dealer , you need 2 obviously
    you will find it easier to do if you have a 10mm ratchet spanner
    drop links are approx £15 each
    to do them you will need a deep 18mm socket and a 17mm open spanner to hold the collar
    drop links should take about 10 mins a side
    arb are a bit more fiddly to get to so should be approx 20 mins a side
    Regular Member monkeez's Avatar
    Apr 2008
    North East
    mine makes the same noise, thats another job on the to-do list then
    Nov 2010
    LEIGH
    mine does the same but when i investigated it i had 2 broken springs
    West Yorkshire
    Good info here, got any part numbers at all?
    Chelmsford
    I have this problem, bought the new ARBs and did the job, but no change. Still horrible squelching noise over speed bumps...
    Drop links are new too...
  1. suspension noise
    By peter-gsi in forum Suspension, Wheels & Brakes
    Last Post: 17th December 2010, 14:29
  2. Suspension noise.
    By Catlene in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2010, 22:57
  3. What's this suspension noise ??
    By AirCooledHeaven in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2009, 14:25
  4. Noise from suspension
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2007, 18:45
  5. Suspension Noise
    By daviek in forum Suspension, Wheels & Brakes
    Last Post: 14th May 2007, 17:11
