Thread: Light come on when key is put in the ignition!!!!
    Regular Member stuart813's Avatar
    gosport
    Default Light come on when key is put in the ignition!!!!
    Hi Guys,
    I have been looking at the wiring at the back of the light switch to see if it will take a unit that includes the front fog switch. After replacing the unit i noticed that as soon as i put the ket in the ignition the headlights came on and i didn't need to turn them on with the switch.
    Does anyone know what i have done to make this happen and how to change it back again???????
    13 Post(s)
    IIRC if the headlight switch is disconnected from the multiplug the headlights will come on. Sounds like you've either not reconnected the plug/socket correctly, trapped and cut a wire, or if you've replaced the light switch with another one, then it's not compatable.
    gosport
    Thanks i'll have a look later
    gosport
    checked light switch last night and the problem was the socket wasn't in correctly.
    Thanks for you help.
  1. Light at ignition off
    By kingarthas in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2011, 17:43
  2. Spanner light on ignition - 3.2 V6.
    By d-suhiti91 in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2010, 12:30
  3. Spanner and Car light when ignition is on
    By ali06 in forum Engine & Drivetrain
    Last Post: 1st August 2010, 20:21
  4. Info light on, ignition off Strange
    By speednut in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2010, 21:50
  5. Ignition Circle Light
    By CristianTM in forum Styling
    Last Post: 17th April 2009, 06:50
vectra c ignition key light
