Results 1 to 10 of 16
Thread: Memory Savers - Any good ?
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Default Memory Savers - Any good ?
    Hi, Just about to change the thermostat on my 2004 1.9 cdti and read that I have to remove the battery and box in order to gain access - this obviously affects several electrical things ie stereo, windows, Ecu, etc and have thought of investing in a memory saver that plugs into the cigarette lighter socket and feeds in 12 volts to keep the memories going, while the battery is removed.
    Just wondering if anyone has used one of these or should I just connect another battery to the leads to keep the memories going!
    Engine : 1.9 CDTi
    They do work but remember the ignition needs to be on so the fag lighter socket is live first.
    Administrator plasma's Avatar
    On the Forum
    579 Post(s)
    Engine : 150
    Mileage : 74000
    eek, I'd never like to back power 12v through the ciggy lighter socket.....
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Quote Originally Posted by plasma View Post
    Halfraud's do that when they change battery.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by keefy*2010 View Post
    So thats another reason not to trust halfords
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    The voltage going back through the lighter socket only has to be a low amperage to keep the memory going - in fact you can put a 9 volt battery in the device that is sufficient to do the job if you do not want to be bothered with using another battery - Now those leads you can buy to jumpstart your car via the cigarette lighter - that is another matter!
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Quote Originally Posted by lee gsi View Post
    Thanks Lee - I found that out this morning - I was hoping the lighter would work on the accesory key setting but it doesn't which means the ignition has to be left on while I do the job - which I wouldn't do. There is another outlet in the cargo area which seems to be live all the time so I will probably use that.
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    I suppose they are fed up of losing stereo codes for customers!
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by alcutler View Post
    Its not only that, you can cause serious damage to some cars by not putting a 12v feed to some cars when changing the battery, Merc's are notorious for this and damage can run into hundreds of pounds apparently.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I had a neighbour wanted to change a dodgy battery without losing codes while I had the classic cars, my solution was connect the new battery to the connections with jump leads before disconnecting old battery, then there's no loss of power, provided you're careful not to dislodge the jump leads before you get the connectors on new battery terminals.
  1. Replies: 28
    Last Post: 31st December 2012, 11:03
  2. Fule Savers
    By chrissy white85 in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2012, 10:14
  3. Do these fuel savers work ?
    By poves in forum The 'Off Topic' room
    Last Post: 19th July 2011, 19:52
  4. Should Have Gone to Spec Savers.
    By ed taylor in forum The 'Off Topic' room
    Last Post: 24th December 2008, 21:53
vectra memory saver
vectra memory saver www.vectra-c.com
