Thread: Vauxhall Signum 2.2 Direct 2004 driver controls rear mirrors dont work
    Birmingham
    Default Vauxhall Signum 2.2 Direct 2004 driver controls rear mirrors dont work
    Hi All,
    Another tricky issue I have came across with my Signum 2.2 direct model year 2004.
    Driver side control works fine for all other controls but one. And that is the rear windows cannot be operated from the driver side controls.
    The rear windows work fine on their own individually whick points to the BCM working fine.
    I took out the driver side control from the door card. Opened the switch up and every thing looks fine. Cleaned it with isopropane. Tested the switch with testing meter and found the button the operating correctly. i.e When the switch is not set to rear windows circuit (switch) is set to open, when switch is set to rear windows control, it presses the switch on the board in and closed (operational) circuit is achieved.
    I also connected it in it's open state after cleaning but it made no difference and was not able to control the rear windows from the driver side.
    All 4 electric windows operate fine individually and the from windows can be controlled by the driver side window controls as normal.
    I am lost at where to go next from here.
    Any help would be appreciated.
    Thanks in advance guys
    Internal mechanism of the switch may have failed or worn contacts
    Administrator plasma's Avatar
    On the Forum
    541 Post(s)
    Engine : 150
    Mileage : 74000
    You had any work or programming done to the car recently?
    Birmingham
    Hi,
    Mechanism looks okay and untouched.
    Birmingham
    Quote Originally Posted by plasma View Post
    Hi Plasma,
    That is the part I am not sure about. The vechicle came with some receipts which were for changing of ignition coils and central locking coils. I will have in-depth look at the receipts for what work was carried out.
    What should I be looking at to get a grasp of issue?
    I have opened an another thread for a differnt issue on the same signum. Central locking door does not operate with remote locking and unlocking.
    http://www.vectra-c.com/forum/showthread.php?t=125713
    Both issues might be related?
    On the Forum
    541 Post(s)
    Engine : 150
    Mileage : 74000
    if they've replaced the Driver Door module they may not have programmed it to accept rear electric windows, theres a special setting on there for that..
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    (or maby its a retrofit for the rear electric windows, and forgot to program it in the module as plasma writes about)
    Birmingham
    HI Plasma,
    The engine managment light is also on. What is the best option to go for. I was thinking to buy OP-COM device from ebay to check the fault code. Would that be able to programme the PDM or BCM?
    Should I try replacing the locking mechanism Or I am wasting time with that?
  1. Vauxhall Signum 2.2 Direct 2004 door locking mechanism
    By nasir600 in forum Bodywork & Interior
    Last Post: 7th February 2011, 23:17
  2. Vauxhall Signum 2.2 Direct Petrol starting problems
    By RogerM in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2009, 14:28
  3. 2004 Vauxhall Vectra 2.2 Direct SRI
    By Curly7 in forum Cars for sale
    Last Post: 1st June 2009, 16:43
  4. FS: Vauxhall Signum 3.2 V6 Elite (2004)
    By Quinten in forum Cars for sale
    Last Post: 22nd November 2008, 08:50
