Thread: Spanner through Car warning light - 2.0DTi
    Regular Member Led's Avatar
    Kings Langley
    Exclamation Spanner through Car warning light - 2.0DTi
    At 0730 on Xmas Eve, I set off as normal for my 8 mile drive to work - no problems, on the return leg at 1600 the car was cold the above light came on after the car started and then went out after 3-5seconds.
    On the 3 or 4 occaisions when I used my car again over the festive period this has happened again but only when the car is cold, never when warm
    The hand book dosn't cover this and I am wondering if it's the glow plugs (car now 6yrs old with 63k), the car drives and performs as the previous 6yrs.
    Any help or guidance is greatly appreciated.
    Engine : 1.9 CDTi
    Does sound like glow plugs,
    Do you have access to a code reader or do the peddle test?
    Kings Langley
    Code reader = No
    Pedel Test = ?? please explain
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by Led View Post
    Code reader = No
    Follow this link to carry out pedal test. Will be interested in knowing if it works for you. It didn't work on my 2.0 DTi.
    http://www.vectra-c.com/forum/showthread.php?t=81742
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    The pedal test doesn't work on the DTi engines as far as I know. Doesn't work on my 2.2 anyway. I'd start with the glowplugs before anything else.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    133 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Quote Originally Posted by cont1204 View Post
    Agreed - I used to have an Astra 2.0 DTI. This is exactly how it behaved when a glow plug failed.
    One word of warning, the glow plugs can seize in place on the DTI. If they don't come out easily then don't try to force them as they WILL snap. Plenty of patience and Plus-Gas is required. Spray plusgas around the thread, wait a few minutes, try unscrewing the plug until it becomes tight, spray plusgas again and screw back in. Keep repeating this exercise - it will unscrew a little further each time until eventually you will have removed it.
    Regular Member lanky659's Avatar
    Jul 2010
    Abingdon, Oxfordshire
    Sep 2009
    Glasgow
    have the same problem on my sri cdti 150 and the code reader shows no codes but will clear the spanner, have also been told it the glow plugs
    south wales
    had a full diagnostics run on the car and was told that the EGR valve needed relacing as well as 4 new glow plugs, have fitted the EGR valve but car still going into limp mode, havent changed the glow plugs yet but would the fact that i have faulty glow plugs mean that the car would go into limp mode?
    Exclamation
    Quote Originally Posted by alunjenkins View Post
    If you mean its going into limp mode and staying like that, then the answer to your question about the glow plugs is no it wont put the car into limp mode.
  1. Car Spanner Light 2.0dti
    By holtie in forum Engine & Drivetrain
    Last Post: 17th January 2013, 16:37
  2. spanner light on no power 2.0dti
    By postman111 in forum Engine & Drivetrain
    Last Post: 11th February 2012, 23:15
  3. help! spanner light! 2.0dti
    By mick p in forum Engine & Drivetrain
    Last Post: 12th December 2010, 18:38
  4. 2.0dti - spanner light syndrome!
    By Littleted in forum Engine & Drivetrain
    Last Post: 10th January 2008, 00:23
  5. Signum 2.0DTI spanner light
    By signum_boy in forum Engine & Drivetrain
    Last Post: 17th May 2007, 22:00
vectra c 2.0 dti pedal test
vectra c 2.0 dti spanner light
vauxhall vectra 2.0 dti warning lights
vauxhall zafira 2.0 dti pedal test
vectra c 2.0 dti spanner light when first
vectra dti limp mode spanner
vectra dti limp spanner hot
vectra c spanner light 2.0 dti
vectra 2.0 dti spanner and car light
car spanner light vectra dti
vectra 2.0 dti spanner light coming on when driving
car with spanner warning light vauxhall vectra
warning lights opel vectra spanner light
