Thread: Oil Change - GM 10W40 any good
    Regular Member mxt's Avatar
    Nov 2010
    J17 M6 Sandbach, Cheshire.
    Default Oil Change - GM 10W40 any good
    Bit of advice please
    2004 SRI 1.8 52000 miles
    I was recommended by dealer
    GENUINE VAUXHALL SEMI-SYN 10W40 ENGINE OIL ACEA A3 5LTR
    £30
    Is this a good value combination for the money.
    I see other people suggesting 5W40 oils on the forum.
    Should I spend the £30 on a different brand?
    Any advice welcome
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Since your car is a non-VVT 1.8 it will do just fine with the 10w40 oil Go for it
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    IIRC, Asda do a 10W-40 semi syn with the same spec for about £15.
    Sep 2009
    Audley STAFFS
    the GM oil is very good but when I first got my 1.8 at 50,000 miles I put the semi 10-40 in, not as smooth as before using a bit more petrol, so I used mobil fully synth 5- 30, very very good, at the next oil change used COMMA fully synth again very good (and cheap) but for my last oil change I have used GM 5w-30 dexos2 fuel Economy long life fully synth, my dealer sells it for 23quid as a kit, you get the oil/filter/ and sump plug rubber seal for under £23.00 a bargain, the car seems to run better than ever, starts easy in the cold weather is smooth to drive and gives a very goos MPG, so yes,,,its fully synth for my little baby,
    PS go to another dealer as 30 quid for semi synth 10-40 is a rip off.
    just noticed your location,, my dealer is in newcastle-under-lyme, its worth a trip.
    Nov 2010
    Thank you for the advice.....
    ".....30 quid for semi synth 10-40 is a rip off. "
    Yes I was thinking that as well - may well try the Stoke Dealer?
    Clomp - which dealer did you use - I notice you are only down the road from me.
    Edit - sorry just noticed the Newcastle dealer you used - Is that Greenhous?
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by mxt View Post
    yes mate,, if you realy want to go with the semi synth, I live at AUDLEY,,I will give you a gallon,, free
    Nov 2010
    For Free - Fantastic - but I will certainly pay you for it.
    I was rather hoping to do the change today as its bank holiday.
    Well TBH I was also fitting a new shower tray as well today but I think the oil has priority while weather is milder.
    Would it be possible to collect the oil today? If so place/time?
    Sep 2009
    Audley STAFFS
    no problem, I will meet you just off j16, come off at 16 go right round the roundabout towards alsager then turn left into the motel/ petrol station, silver lightning 53 plate sxi,, say,,, 1130/1200 is that ok, have you got a filter?
    Nov 2010
    Sorry just realised you were offering semi-synth - however after reading your comments and the price at Newcastle Vx I will probably go for the GM 5w-30 dexos2 deal
    EDIT:
    Think we just posted at same time ! Thanks for the offer - it was very kind of you
    Sep 2009
    Audley STAFFS
    EDIT:
    no problem,, all the best, rgds ANT,
  1. Some good news for a change !
    By FIL 4822 in forum General Chat
    Last Post: 25th June 2009, 14:19
  2. Had some Good News for a Change!
    By dennis_signum in forum The 'Off Topic' room
    Last Post: 18th June 2009, 18:31
  3. Vectra 1.9CDTi SXi (150), 5w30 or 10w40 oil?
    By VXR CDTi in forum Diesel Engine related
    Last Post: 1st February 2008, 18:34
  4. 10w40 or 5w30 Grade oil in a 54 plate Cdti 150 ?
    By DeanF in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2008, 13:13
  5. 10w40 oil in 1.9CDTi?
    By Vectra Singh in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2007, 15:28
genuine motor oil 10w40 forum
gm 10w40 engine oil review
gm 10w40 engine oil
1040 semi synthetic oil in vectra 1.8
is 10-w40 engine oil for vauxhall vectra
gm 10w40 oil specifications
vectra c 1.8 oil 1040
is it safe to use 10w40 for vectra
1040 oil in vectra c 1.8 is it ok
opel vectra c 10w40
is 10w40 ok for a 1.8 Vectra
gm 10w 40 oil spec
