Thread: Vectra 3.0 idling problem
    Bucks
    confused Vectra 3.0 idling problem
    Hello
    I bought a vectra 3.0v6 diesel about a month or so ago and have had nothing but trouble. When i bought it there was a known problem that the car stalls while idling, and the garage i bought it from promised to fix it. It has been back to the garage twice now and they havent fixed it so i thought i would have a go at diagnosing the problem myself so i could go back and tell them what it is or fix it myself if its not going to break the bank.
    There are so many things that ive found it could be! The idle control valve, egr valve, spark plugs.....
    I no there are many threads already about these topics but all the links to the pictures or guides dont work anymore so i dont no where to start
    Please can anyone help
    Thanks,
    Neil
    PS The garage have replaced the fuel rail pressure sensor and tested the fuel pump and its ok.
    If the fault developed within the first 30 days and the sales outlet have agreed to fix it, then they should
    Don't go tinkering with it, they could decline any future repairs
    Stalling during idling will require a diesel mechanic with experience of the Y30DT engine to examine it
    Phone around and see if any have worked on an Isuzu Y30DT and can perform a diagnosis
    However, since it is a hyrbid it may require a visit to an experience Vectra C mechanic to check the other components
    Start with the basics; fuel filter, fuel tank, fuel lines, fuel pressure readings, etc
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    15 Post(s)
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    When you find the sparkplugs!!!! let me know.....
    Try cleaning the throttle butterfly and check its working properly....
    Bucks
    thanks m8internet. Its just getting really frustrating now. They say its all fixed, then i go out in it and it happens again! lol. I just want it all working ok because other than this problem im really happy with it.
    Oh and i forgot to mention that it only happens when the engine is warm?
    Bucks
    Lol omega63. Dense moment there lol. As you can tell im no mechanic lol.
    Is the throttle butterfly easy to clean?
    Jul 2010
    15 Post(s)
    Mileage : 126,000
    Thumbs up
    The best way to clean the throttle butterfly is to take it off, x4 nuts and x1 vac pipe. While its off you can check that its not sticking shut, if it sticks shut the engine will loose power, black smoke, and almost certainly stall cut out. Location is front righthand corner where the large rubber induction hose is, hope this helps......
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    If it's a facelift it will have an electronically controlled valve.
    I suggest you get the codes read and fuel pump pressure checked again WITH YOU LOOKING. They could be talking crap...you never know...
    Try injector cleaner and change the fuel filter.
    Sep 2010
    Bridgnorth
    I had a similar problem with mine and one of the symptoms was it cut out after starting it up (3.0 v6 diesel) eventually kept cutting out when running. In the end the problem was simple, turned out to be a lose connector going into the ECU, so check all of these and make sure they are thoroughly cleaned, at one stage I was quoted £4,600 for new injectors. Try this trick though, it might just work.
    Quote Originally Posted by vectra3.0-owner View Post
    Try to recreate the circumstances, before accepting the car after next visit
    This may mean taking the car to them very early and requesting they perform the diagnosis before 10:00
    You can then sit in it, allow it to warm up, drive it around a bit, then return and advise them
    The dealership I use is quite happy to accept this request
    I then pay on my return, if the fault has been corrected
    The work then carries a 3 month warranty
    I usually drive on a variety of roads for about 2 hours; 1 hour there and 1 hour back
    However if the fault is still present it usually appears within the first 15 minutes!
  1. Problem...? Vectra SXI...problem with starting after filling with fuel?
    Last Post: 21st October 2022, 12:25
  2. 2003 vectra c 1.8 ls starting/ idling
    By Tank988 in forum Engine & Drivetrain
    Last Post: 6th May 2011, 23:44
  3. 2000 1.8 sxi idling problem
    By Rambo77 in forum Engine & Drivetrain
    Last Post: 9th February 2009, 18:59
  4. 2.2 idling
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2008, 09:00
  5. Idling
    By Daywalker in forum Engine & Drivetrain
    Last Post: 10th May 2008, 08:23
opel vectra c 2003 3.0 diesel problem
why my opel signum 2003 3.0 engine idle
