Page 1 of 7 123 ... LastLast
Results 1 to 10 of 63
Thread: any one replaced the ecu?
    Glasgow
    Default any one replaced the ecu?
    hi guys im running another post as well as this one, so as the title states, has any one replaced their ecu due to failure? if so what was done? cost etc?
    please see my other thread for my current problem
    http://www.vectra-c.com/forum/showthread.php?t=125531
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Never heard of this before. When you had your car remapped did the tuner open the ecu using a bdm or did he remap via obd?
    Do you have the hardware and software number from the ecu? If you have printed a fault code from your car they will be there. If thise number match the ecu you found on e-bay you can use this ecu, only program the immobilizer.
    Glasgow
    when i plug the laptop in it wont connect to the ecu..
    so i hope vauxhall will be able to tell the actual problem..
    Regular Member benny's Avatar
    Feb 2006
    dudley
    you need to start simple here .... check all fuse's ...does every thing in the car work as it should do without the engine running ..can you comunicate with the power steering system ?... have you had any work done on the car in recent weeks ? ..
    Glasgow
    all lights etc work, the laptop shows faults with all communication systems, the steering etc it shows fault codes for it all, but when it comes to communicate with the ecu it cant.
    Glasgow
    i didnt know what fuses to check..
    their is a ticking comming from the ecu when i turn the ignition on, its like 4 clicks and when i unplug it, the clicks dont happen but everything else still works, lights, fan etc etc and the lights on the dash stay the same..
    Feb 2006
    dudley
    ignore all the truble codes ..... can your laptop talk to the powers steering system ? can you get data and codes from the power steering system ..?
    Glasgow
    no i can get them because i wont communicate with the ecu..
    you thinking the CIM?
    i cant understand why the ecu would just pack in though..
    Feb 2006
    dudley
    ?........?.........?........ can you comunicate with the power steering system yes or no lol..?
    Glasgow
    its difficult to answer lol, the fault summery gives a list of all the systems and the amount of fault codes, so technically i think the answer is Yes it can communicate.
  1. What do I need replaced
    By m20_swe in forum Engine & Drivetrain
    Last Post: 25th March 2012, 08:45
  2. Anyone replaced cd70 Nav?
    By Carmaduk in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2011, 08:12
  3. Replaced 'stat- still not right.
    By jimmyred in forum Engine & Drivetrain
    Last Post: 23rd January 2011, 23:42
  4. maf replaced still need help
    By scutster in forum Engine & Drivetrain
    Last Post: 15th May 2010, 10:16
  5. Just had my DMF replaced in ££££ shocker!!!!
    By Westy SRI in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2009, 19:47
