Thread: Tailgate problems on signum
    Fife
    Default Tailgate problems on signum
    The electric Tailgate on my signum elite as stopped working. I noticed this after washing it the other day - it would not open. The symptoms are
    1. When I unlock the car using the remote fob, you can hear the mechanism unlocking the tailgate, but when you try and press the button on the tailgate to release it, nothing happens.
    2. When you open( and sometimes close) one of the doors on the car, it releases the tailgate latch so its partially open. However if you the try and lift the tailgate, it lifts a fraction but wont open it becuase the latch is still on - if you press the button on the tailgate nothing happens. It shows as open on the dashboard and I have to push it firmly down to close it again
    All seems very weird...anyone got any ideas? Might it be something as simple as a blown fuse?
    Thanks,
    Decho
    Bristol
    I've JUST had this problem on mine!
    Inside the rubber cover is a metal plate which is pushed up onto a switch which activates the electronic mechanism. There is a little ball bearing which I don't know what it does, but it gets stuck and holds the plate up against the switch causing the problems you describe.
    To resolve, pull the rubber boot off the switch and you should be able to use a key to pull the plate down. Spray lots of WD40 into the bearing and push it in a few times. Now test by trying to use it as normal (minus the rubber boot). At first it made no difference on mine so I left it a couple of days which let the WD40 work and now it works as it should.
    The only problem I've got now is figuring out how to get the rubber boot back into place!
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Had this problem too... very embarrassing when you want to get into the boot and it doesnt do anything. I found it sometimes doesnt lock properly. Press down on the boot as you press the button as if you were trying to spring it open lol. It knocks whatever gets stuck into position so that the electric motor will activate
    Not had a problem since this... oh and although the number plate makes that horrible rattle... make sure you give the boot a bit of a slam. I found its when your a bit too gentle Hope that helps
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by Gayno View Post
    ...The only problem I've got now is figuring out how to get the rubber boot back into place!
    You'll have to either remove the trim on the inside of the bootlid so that you can unbolt the handle mechanism, or cut off the wrapover edges of the rubber boot and silicone it into place from the outside.
    BTW, a revised boot handle mechanism is available that doesn't have the ball bearing in it.
    Bristol
    Really?
    I assume from Vx, but how much?!
    S.E
    About £13 when I bought it a while ago.
    Bristol
    That's cheaer than I was expecting!
    Do you have a part number?
    If I've got to remove it to reseat the rubber boot, may as well just replace it with a newer unit!
    Didn't Duncan do a how 2 for the sticky switch problem?
    Wales
    Bristol
    Brilliant, and this will fit the pre-face models as well?
    (assume they are the same rear)
  1. tailgate problems
    By veccysri150 in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2011, 15:10
  2. tailgate problems
    By trickyjacks.4 in forum Bodywork & Interior
    Last Post: 27th October 2010, 08:09
  3. powered tailgate problems
    By a wood in forum Bodywork & Interior
    Last Post: 22nd October 2010, 13:11
  4. Power Tailgate problems
    By purple170503 in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2009, 22:51
2011 vectra tailgate problems
