Thread: No fan on setting 1?
    Oct 2010
    Lincoln
    Default No fan on setting 1?
    I suspect I have a failed resistor pack as I have no blower fan on setting 1 but 2,3,and 4 are fine. Anyone know where the resistor pack is located on a 56 plate Vectra C?
    Oct 2006
    southampton
    16 Post(s)
    remove glove box matey and its on the right hand side HTH
    Oct 2010
    Lincoln
    Any idea what it looks like?
    Oct 2006
    southampton
    16 Post(s)
    ill find one on ebay to show you ok, 2 mins
    Oct 2010
    Lincoln
    Many thanks
    Oct 2006
    southampton
    16 Post(s)
    Here you go HTH
    Oct 2010
    Lincoln
    Thanks, looked at those BUT he's saying if it's stopped or only working on setting 4? Mine works fine on 2,3,and 4 just nothing on 1?
    Oct 2006
    southampton
    16 Post(s)
    still the resistor causing it matey, bout £25 from dealer.
    Regular Member Dazzy2006's Avatar
    Notts
    When my resistor went i lost 1,2&3 - tofix mine i bought a resistor from maplins for about 75p and repaired it myself
    Regular Member Robsey's Avatar
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    The resister pack is made up of 2 or 3 resisters...
    The speeds are achieved by using the resisters as follows
    Speed 4 = bypass the resisters
    Speed 3 - via resisters 1 AND 2 in parallel, or a resister No 3 only
    Speed 2 - via resister 2 only
    Speed 1 - via resister 1 only
    So if you lose speed 1, then resister 1 has gone open circuit...
    if you lose speed 2 only, then resister 2 has failed
    and so on
    if you only have speed 4, then the whole resister pack has failed, usually due to the thermal fuse.
    This is a theoretical answer, using basic electronics theory... however I cannot state exactly the format / configuration of the resisters within the pack.
  1. tuning box what setting do you use??
    By bangty 1 in forum Diesel Engine related
    Last Post: 29th October 2010, 09:55
  2. setting the clock
    By magpie in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2010, 16:05
  3. setting time
    By rob warrington in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2010, 00:57
  4. Fan only working on top setting
    By devore in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2010, 15:15
  5. Setting up in business...
    By JCB in forum General Chat
    Last Post: 11th May 2006, 15:41
