Results 1 to 10 of 15
Thread: for fitting lowwering spprings
    Regular Member mrk's Avatar
    14:88 our time will come
    StatsVehicle Info
    Default for fitting lowwering spprings
    could someone give me a rough idea so i know i'm not being ripped off ,and is it an easy diy job - time ,equipment req, etc( i'm thinking eibachs)
    thanks
    Admin plasma's Avatar
    On the Forum
    136 Post(s)
    StatsVehicle Info
    136 Post(s)
    Garage would probably charge approx 75 or so. Would take about an hour max with all the proper equipment, bench mounted spring compressors etc etc....
    average person not owing a garage about 30-50 and would take about 2hrs not rushing it...
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    StatsVehicle Info
    Have a look in guides section so you can see if you think its easy or not.
    A garage would probably charge 2 hours labour to fit them.
    Regular Member vauxhall-john's Avatar
    fife, scotland
    StatsVehicle Info
    depends on how much the garage you take it to charge for labour? only unusual tools you should need are spring compressors for getting the old springs off the struts, everything alse you should be pretty straight forward tool wise,
    depending on how easy the bolts are to come off the car i could prob do them off a jack in around 2-3 hours, but obv a garage will do it off a ramp, so will be easier,
    just phone up and ask around for prices, hth
    Jul 2006
    Northampton
    StatsVehicle Info
    Need the tool to remove the top bolt from the mount. seems like a bit of a specialist tool to me unless anyone can advise otherwise...?
    Regular Member Jezzy's Avatar
    S.E
    StatsVehicle Info
    A box spanner would do, or crack off the top nut while the strut is still bolted in place on the car.
    StatsVehicle Info
    Quote Originally Posted by Danwells72 View Post
    What one?
    The Torx one or the 22m swan neck spanner.
    The 22mm one is the one most people have problems with as it tends to spin the whole piston rob whereas the garage has air tools (Or electric impact guns) that shock it off.
    Another bolt you may have problems with is the drop link nut as they can just spin the whole drop link joint if your unlucky.
    Here
    23 Post(s)
    StatsVehicle Info
    23 Post(s)
    Its an easy job on the back as you only have to undo 1 nut at either the top or bottom of the shock absorber to change the spring. Fronts a bit more involved and obviously require spring compressors to do the job safely. Should be abut a hour to an hour and half's work for a garage as long as they have no issues with any seized nuts etc.... Save your self some cash and do the back yourself and get a garage to do the front.
    On the Forum
    136 Post(s)
    StatsVehicle Info
    136 Post(s)
    Vortex sockets for the top mount nut and male torx for the insert.. As for drop links never had one spin on me yet as theres a flat on the back of it to stop it from turning
    Full Member Aikon58's Avatar
    Englandshire
    StatsVehicle Info
    Thats how i did mine
    Quote Originally Posted by plasma View Post
    Both good bit's of info
  1. hid fitting
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 18:25
  2. HID Fitting Help!
    By Adam-morrison in forum Electrical & ICE (including SatNav)
    Last Post: 30th March 2010, 13:21
  3. USB fitting
    By chinarose87 in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2010, 17:21
  4. HID fitting?
    By arkhan78 in forum Styling
    Last Post: 13th December 2008, 07:00
