Results 1 to 10 of 11
Thread: air conditioning
    walsall
    Default air conditioning
    thinking ahead to the warmer months,last summer went to use my air conditioning no cold air,so took it to West Mercia Radiators,they done a check and it was empty so refilled it,it was ok for aprox 10 days and it went empty again,so back to WMR were they kindly filled it up free of charge again and pressured tested everything was ok so off i went,aprox 10 days again it was empty so took it back,again they changed the two valves were they connect the pipes and refilled it free of charge and left it on the pressure test for 30min,no sign of pressure loss,off i went again then 10 days down the line empty again,by now the summer was nearly over so thought i would leave it to later on to get it done,what i dont get if its holding pressure weres it leaking from,anybody else have the same trouble and give me some idea whats happening
    If your losing it then it must be leaking. If they couldn't find the leak then I'd suggest trying somewhere else.
    Regular Member Jezzy's Avatar
    S.E
    Find a place that uses a dye, that way when it leaks out the dye will show up.
    Regular Member Robsey's Avatar
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    Possibly a dried seal...
    Air-con needs to be run approx once every month, to keep the various seals from drying out...
    or you may have a very fine pin-hole in the pipe-work etc somewhere.
    as said above, get it tested using the coloured die...
    Nov 2010
    North Yorkshire
    Vehicle : Signum Elite 1.9 CDTI
    Engine : 1.9 (150)
    Mileage : 113.000
    Quote Originally Posted by Robsey View Post
    I've been wanting to see how well mine works on my Signum, how do you check it? On my Peugeot there's a button marked AC, press it and the aircon comes on.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Quote Originally Posted by alhambra View Post
    * symbol button on the console beside the heater control activates the AC.
    Regular Member jim skeen's Avatar
    kelso scotland
    Default a/c vectra c v6
    Does anybody out there know how long, after switching on yer a/c, it takes to notice a difference in temp of the incoming air?
    Usually you have to wait until the engine is warm
    Turn the heating motor to cold, position 4, and face
    After about 15 seconds, put your hand about 6 inches from the centre air outlets
    I use a thermometer attached on the roof, and watch it fall to the blue digits, around 12'C within about 60 seconds
    Well, normally there is a thermometer, but it fell off a few weeks agol bounced on the passenger seat and I can't find it...
    Sep 2010
    north east uk
    That is something i didnt know, thank you. This my first air conditioned car, so its all new stuff to me.
    13 Post(s)
    Usually you have to wait until the engine is warm...
    That's news to me. My AC starts to work pretty much straight away in the summer and is icy cold at the vents within a minute tops.
  1. Air Conditioning
    By scarydeath in forum Vectra C / Signum Troubleshooting
    Last Post: 21st April 2012, 20:32
  2. air conditioning
    By andyd in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2010, 11:39
  3. Air conditioning HELP!!!!
    By s0501291 in forum Engine & Drivetrain
    Last Post: 1st June 2009, 11:44
  4. air conditioning fan??
    By alexander08 in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2008, 15:47
  5. Air conditioning
    By cbee101 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2008, 14:44
