Thread: change clutch as well
    walsall
    Default change clutch as well
    ive been having my dmf rattling now for the last 2 years or 25000miles,its started to get a bit louder and have decided to get it changed,ive phoned and visited a few garages to get some quotes,and a lot are saying that i might not need to change the clutch until they can strip it down and have a look at it,my question is if the clutch looks ok shall have it put back in or replace it with a new one while its all stripped down.
    thanks for any info
    Glasgow
    you may as well mate, but if it still has a lot of life then you could just save some cash and replace further down the line..
    Engine : 1.9 CDTi
    Its worth doing it at the same time so it saves you £300 odd in labour when the clutch does need doing.
    Bristol
    Vehicle : CDTI 150
    A clutch kit with CSC is £270, and will have been worn by the excessive wear in the DMF.
    Its realy a false economy as Auto data quotes 5hrs for a clutch change unless you are about to sell the car its best to take the hit. I did.
  1. Dmf and clutch change
    By Signum150 in forum Engine & Drivetrain
    Last Post: 5th March 2012, 22:04
  2. Can I change DMF and not the clutch
    By marky2027 in forum Engine & Drivetrain
    Last Post: 12th February 2012, 19:47
  3. how do i change clutch on 2.0l dti
    By kez in forum Engine & Drivetrain
    Last Post: 20th May 2010, 19:51
  4. clutch fluid change
    By nikroc in forum Engine & Drivetrain
    Last Post: 16th November 2009, 23:44
  5. Clutch Change?
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2006, 18:04
