Results 1 to 10 of 17
Thread: Has anyone ever replaced a caliper bleed nipple?
    Regular Member sheepish's Avatar
    Yorkshire
    Default Has anyone ever replaced a caliper bleed nipple?
    Hi all,
    My Vec-C is due a fluid change and one of the nipples is pretty rounded, so I'm thinking now's the time to bite the bullet and get it replaced, so if anyone can share thier experiences...???...
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    fluids n nipples...wots this world coming to ? lol
    aint had any experiences with this m8,sure someone will put you wise though
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    Well I swapped some from one set of calipers to another, whats the question, how to remove a rounded off one? Firstly try a bit of heat and molegrips, if that doesn't work you can take the caliper off then lock the nipple in a vice and rock it backwards and forwards to loosen it up.. You can always try stud extractors but they are better at gripping larger diameters. Lastly take the caliper to a garage, they will probably remove it for a tenner. Its down to theirs and your determination in the end. You can pick up a secondhand caliper for peanuts thesedays if it becomes to much of a pita.
    VX should sell spare bleed nipples..
    West Yorkshire
    What gets me is the quality of the bleed nipples. They are like butter!!!
    I don't expect titanium but ffs, I could almost round one off with my fingers!
    Regular Member JagRigger's Avatar
    Norfolk
    15 Post(s)
    Engine : 1.8 VVT ( No2 ! )
    Mileage : 310 k !
    I snapped one off once on the Cav.
    Had to remove the calliper and drill it out
    Aug 2010
    Dundee-Motherwell
    for as long as i can remember..bleed nipples have always been made outta soft c**p and i always ended up rounding them off..1st sign of it and i would re-new
    Oct 2006
    southampton
    16 Post(s)
    Still waiting to do my brake upgrade but have all stainless bleed nipples and banjo bolts to go on so should avoid some of the issues of becoming seized, they are pretty cheap too HTH
    Yorkshire
    Hi Lizard,
    Where did you get the stainless nipples from? ...or did they come with the caliper?
    Oct 2006
    southampton
    16 Post(s)
    Quote Originally Posted by sheepish View Post
    Hi Lizard,
    Ebay matey, cant remember where but they are either M12 x 1.5mm thread pitch or 10mm x 1.5 TP, i'll have a look now for you....
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Heres a tip for you when trying to remove dodgy looking bleed nipples, fill the kettle full, boil it then slowly pour the boiling water over the bleed nipple and then see how easy it comes out.
    Brake fluid change is on the cards for me as soon as the better weather makes an appearance. I will defiantly change the nipples too. Are these available from the dealers or does anyone know the size that is required?
  1. Bleed nipple size
    By dilan in forum Suspension, Wheels & Brakes
    Last Post: 7th November 2012, 13:41
  2. Clutch bleed nipple
    By Imraldis in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2012, 21:19
  3. seized rear calliper bleed nipple
    By DaveG in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2012, 23:36
  4. Rear brake caliper bleed nipple
    By tony_b in forum Suspension, Wheels & Brakes
    Last Post: 9th March 2011, 18:45
vectra c bleed nipples
bleed nipple size vectra c
corsa c front brake caliper bleed nipple thread size
how to remove a seized car bleed nipple
