Results 1 to 10 of 24
Thread: MOT on Tuesday, emissions.
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Default MOT on Tuesday, emissions.
    Got my dreaded mot on tuesday and as this will be the first time since owning i'm not looking forward to it.
    Got to change my show plates back to standards and on the service they picked up on my m-tec sidelight bulbs but i could have a more serious issue.
    Firstly the outer mesh on the flexi had come off at either end so last week i cut it off but noticed a ever so slight blow, thats not a problem as i will get the car over the pit at work tuesday morning to put some exhaust paste on it as a temporary fix. The issue might be the emissions, now when i had the exhaust done at MIJ i got a decat too and just run from the 2 precats (GSi) but when i got a mate to check the emissions on the machine at 2500 rpm he said it was borderline. I'm sure i have read somewhere you can buy something to put in your fuel that will lower the emissions slightly so has anyone any ideas as i can't be without a car now i work 20 miles from where i live with no public transport to get there.
    P.S. Happy new year peoples.
    Jul 2009
    The Rift, Cardiff
    Make sure the engine is up at normal running temp, idealy go for a long run and give it a bit of a thrashing before taking it in. I think diesel redex helps to reduce them too.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Please don't go putting diesel redex into a GSI as there is the possibility of killing the pre-cats and even worse causing the car to run smokey as there is diesel in diesel additives.
    As said take it out for a good hard run to get the cats up to temperature and you could also add some Cataclean or similar. Good luck mate as mine will be up on Wednesday
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    give it a good blast on the way to the test centre
    mine failed on the side lights i had mtec's in the tester said they wasn't white i had the same bulbs in the number plate but there not covered colour of bulb.
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Thanks for that John, i'm not that silly to put diesel additive in a petrol car.
    I've found on the net a few places that are Cataclean stockists so shall be going and getting some as i'd rather be safe than sorry.
    Quote Originally Posted by yorkshireborn View Post
    It's a bit silly that, taking mine out today as when my Vauxhall dealer serviced the car a few months back they quoted £25 to change the bulbs. Taking it back there as i've got a free mot with them.
    Jul 2009
    The Rift, Cardiff
    Oops, for some reason I presumed you had a diesel
    Engine : 1.9 CDTi
    Yeah get it really hot and if its still boarderline take the air filter out too as that helps a bit.
    Essex
    28 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    If its boarderline ...they usually pass it,on my last one it was and he just added that their machine was playing up a bit and passed it
    But as said dave get it nicely warmed up first ....good luck and hopeful;ly see you Sunday .
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    Right can't do much more now but pray (i'm not religious), standard numberplates back on, m-tec's removed, all fluids checked, tyres and pressures checked, all lights checked.
    Only thing left to do is to put the Cataclean i bought this morning in the fuel tank and then put some exhaust paste on the end of the flexi to stop the slight blow.
    Fingers crossed.
    milton keynes
    Good luck mate , fingers crossed it passes.
  1. get my new car on Tuesday
    By smurfy in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2009, 20:04
  2. Tuesday Joke
    By spennny in forum Comedy & Humour
    Last Post: 17th March 2009, 10:58
  3. Tuesday 14-10-08 Rant
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 15th October 2008, 21:53
  4. Tuesday Birthdays!!
    By Mrs D in forum The 'Off Topic' room
    Last Post: 1st July 2008, 22:50
  5. Tuesday Birthdays!
    By BlueRob in forum General Chat
    Last Post: 13th May 2008, 16:57
