Thread: torque settings
    preston
    Default torque settings
    if TIS suggests torque settings like this
    85 + 75° + 15°
    then i get first bit but what does second and third numbers mean?
    cheers
    Regular Member benny's Avatar
    Feb 2006
    dudley
    rotation .....angle ......
    Administrator plasma's Avatar
    On the Forum
    551 Post(s)
    Engine : 150
    Mileage : 74000
    u can buy a template to put on your torque wrench.. so once up to the correct torque you can then turn it by the amount of degrees needed
    Glasgow
    Torque setting of 85. Once it clicks give it a 3/4 turn, stop then give it a last little nip up.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Some have to have a torque setting, then dial turned, could be that. 85ftlb then 75 degrees then a further 15 degrees?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I have just bought one of these for that very reason
    http://www.amazon.co.uk/gp/product/B...M0HB1MNT5K9ADY
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Got the very same one mate. I'm finally getting a real tool set together with everything I could ever need, its great having the proper things to hand.
    Glasgow
    Ignore my post i have typed a lot of nonsense.
    preston
    thanks
    i'll be off to get one of those tomorrow
    is there a reason why they use angles in addition to torque settings?
    does it confer some difference over just using torque settings?
    On the Forum
    551 Post(s)
    Engine : 150
    Mileage : 74000
    properly is a difference. not sure if its to do with twisting a bolt past its limit? or could be tighten to torque... rest... lets the bolt mating surfaces settle... then torque up 45% ... rest.. then torque to 15%... could all be to allow it seal/do up without too much of an inital impact? could all be a load of carp what i just said...
    But imagine undoing a glowplug, rather than just going striaght at it instead you turn 45%.... rest... turn 15%... rest... then complete undo.. starts to make sense..
    edit: also something nagging in the back of my head about bolts stretching as well
  1. Torque settings
    By signum_rob in forum Engine & Drivetrain
    Last Post: 10th November 2011, 11:39
  2. Torque Settings
    By lizard in forum Handling & Braking
    Last Post: 21st June 2011, 17:27
  3. Torque settings
    By Exclusive BV in forum Suspension, Wheels & Brakes
    Last Post: 28th March 2011, 21:37
  4. Torque settings ?
    By themarbleman in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2011, 09:50
  5. Torque settings??
    By Griff72 in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2010, 19:42
