Thread: replace coolant tank.
    hull
    Default replace coolant tank.
    Hi all, my 06 vec sri has the coolant warning light on the dash even though it's topped up ok. I think i'll have to replace the coolant tank as the sensor must be faulty as there's something floating around in there, where's the best place and price? stealers?
    Also how much coolant will i need when i drain the system? 2ltr enough?
    thanks.
    Administrator plasma's Avatar
    On the Forum
    549 Post(s)
    Engine : 150
    Mileage : 74000
    If its jsut the header tank your changing why not just look at getting a sensor and sealing washer/grommet for it? Even if you decided to change the whole lot you'll just need to replace what you've lost out of the header tank
    hull
    Thanks plasma but i think i'll have to replace the header tank as the float thingy inside the tank is just floating around the surface, broken off i think.
    Jul 2009
    The Rift, Cardiff
    I changed mine not long ago as it was leaking. Easy job, drain 2 litres via the tap on the radiator or fully drain and flush the engine and rad if your filling with new coolant. Disconnect sensor wire then the two small pipes taking note of which pipe goes where. I found it easier to leave the larger bottom pipe untill the tank is released from its mount to get better access to the clip. To remove the tank just push/lift it towards the windscreen untill locking tabs disengage then lift it out of its mount. You can now remove the bottom pipe easily. Refit is reverse.
    The cooling system capacity is 5.5 litres on the 1.8 and 7 - 8 litres on all other engines. I used the Vaux longlife orange stuff (£4 /1 litre, £16 /5 litres at the dealers), at a 50/50 mix with tap water it protects down to -38*c
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    i put a new one on a few years ago dead easy job header tank cost me £37
    hull
    Quote Originally Posted by ChrisBilly View Post
    Quote Originally Posted by yorkshireborn View Post
    cheers guys
  1. Coolant Expansion Tank
    By Telboy in forum Engine & Drivetrain
    Last Post: 2nd May 2011, 21:11
  2. coolant tank cap
    By melvin in forum Engine & Drivetrain
    Last Post: 4th December 2010, 00:05
  3. coolant tank sludge
    By vectra3.2dave in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2010, 22:39
  4. Split Coolant tank 2.8 V6
    By luke4487 in forum Engine & Drivetrain
    Last Post: 1st November 2009, 10:16
  5. Coolant tank
    By John2360 in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 14:09
how to change insignia coolant tank
how remove a coolant tank 06 vectra
vauxhall vectra header tank sensor
vectra c coolant change
vectra c 1.8 coolant replace site:www.vectra-c.com
how to replace collant tank on vectra
how to fit expansion tank vauxhall vectra
how to remove opel zafira coolent expansion tank
replacing coolant header tank insignia
vauxhall expansion tank removal
how to remove a Vauxhall omega header tank
vectra c coolant reservoir
holden vectra coolent container
sensor for radiator bottle for vectra
faulty float in coolant bottle of vauxhall insignia
how to remove expansion tank from a insignia 1.8
opel Vectra something floating in the radiator expansion tank
vauxhall insignia coolant tank removal
how to by pass water float signal on vectra c
replace coolant tank on vauxhall omega v6 3.0
mix tap water to coolant for opel vectra c
antifreeze container vectra
replacing expansion tank on vauxhall
vauxhall signum coolant tank easy to fit
vectra c header tank pipe pics
