Thread: Registration light turned always on
    Norfolk
    Default Registration light turned always on
    Hi , looking for some help with rear registration lights.
    They are always turned on until I lock the car. So when i forget to lock the car overnight in the garrage the battery is getting almost flat.
    Do I need a TECH2 to fix it or is it some weird wiring problem?
    / BTW have rear parking sensors wired to break light. /
    Any help appreciated
    Blantyre
    Rear parking sensors shouldbe wired to your reverse lights ?
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Mine do it to but I never leave my car unlocked overnight.
    Just lock the car when its in the garage?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    i turns off by the time the car have been told to do so.. between 30 seconds and 30 minutes.. (or just lock the car..)
    13 Post(s)
    Quote Originally Posted by banjokazooie View Post
    Have you checked to see if the boot light goes out when you close it? If it's staying on then the numberplate lights will also stay on. Could be a dodgy switch or the boot catch needs re-aligning.
    The boot light will switch itself off after approx 5 mins. The numberplate lights should also turn themselves off unless the boot is still opened. The boot light will turn itself off after approx 5 mins regardless whether left open.
  1. Registration Light
    By Clugie in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2009, 12:35
  2. Rear registration LED light
    By anthonychall in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2009, 10:54
  3. Look what turned up
    By parsco in forum Detailing and Car Care Discussion
    Last Post: 28th April 2009, 22:33
  4. Changing the back registration plate light bulb...
    By L11Marc in forum Vectra C / Signum Troubleshooting
    Last Post: 16th February 2009, 02:51
  5. Can the tailgate light be turned off
    By Pjuk in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2008, 05:23
