Thread: A bit of advice please
    Nov 2010
    luton
    Default A bit of advice please
    Hi Guys
    Ive got a 2004 1.9CDti 150 estate, done 60,000 miles
    Ive listened with great interest to all the comments but have absolutely no idea about what some of the are that youre talking about
    anyway...
    since new, its had its regular servicing, some VX dealership, some local garage when funds are low
    I want to keep this car for a good few more years so just want advice as to what i should be looking at replacing/ cleaning out etc to keep my baby at ultimate working order, ive heard you all talk about swirl pots and EGR valves but frankly have no idea what they do etc?
    help please !!!!
    Aug 2010
    Leeds
    Ok just keep reading and look at the links folk post up and learn also look on google for information & the Haynes manual for your car is available a great source for help.
    As for keeping this car running leave it alone.!!
    What i mean is if it's ok leave it only get the spanners out if it's broken & get it serviced every year & it will run forever more.
    Too many tinker and then balls it up if your not competent yet leave well alone.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    EGR Valve - Exhaust Gas Recirculation Valve - the EGR system is designed to send some of the exhaust gases back around to mix with the intake air to be burnt again and thus burn any residual fuel in it, whilst also raising the temperature of the intake air more quickly from a cold start. The faster the engine can get up to normal operating temperature, the faster the catalytic convertor(s) can work better.... and the lower the vehicle's emissions.
    The valve is a solenoid about the size of your fist, mounted on or about the exhaust manifold (position depends on engine). It will become coked up after a while and can jam. It is easily removed to allow cleaning.
    Swirl Valves as I understand them are similar to a throttle butterfly in design and are designed to alter the airflow into the engine dependingon certain parameters. Low revs needing less air for better performance than high revs, which needs masses of air coming in. Bit like an indiviual air throttle for each air intake for each cylinder, but typically all operated by a common rod.
    In some engines the operating rod assembly can become detached (due to poor design) rsulting in lousy performance.
    Mileage : 000
    Aug 2009
    sheffield
    i have a 1.9 cdti 150. just keep to service intervals,and i clean my egr valve out every 6 months ( i have a spare ,i just swap it over ) look in the how 2 section very good.
    Regular Member david.aka.judas's Avatar
    Suffolk
    on top of the info, I would recomend that you go to any of the meets, local or not. you can ask some probing questions and we can point...
    it will come with time.
    Nov 2010
    luton
    great stuff
    many thanks ;-)
    Essex
    29 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    Quote Originally Posted by david.aka.judas View Post
    and your good at pointing arnt you David lol ............
    and if your not busy next sunday poppinch we have a meet at lakeside
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 25000
    Quote Originally Posted by Bigtee View Post
    If it ain't broke.........
    Regular Member Jezzy's Avatar
    S.E
    Leave it alone? Baloney. It's got a turbo, so do oil changes as frequently as you can afford, and use the best oil you can get.
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
