Results 1 to 10 of 20
Thread: red diesel
    belfast
    Default red diesel
    hi,having a bit of a debate with a friend,will red diesel damage your car???(not that i would be using it )ive been told that its the same as what you would buy on the forecourt only with a red die in it,hard to imagine if it would if the use in in diggers etc which are very expensive,altough i know customs dont take to kindly to it,(would get less punishment for murder now days )please help me put this on to sleep,many thanks
    Regular Member rjw's Avatar
    Oct 2010
    cornwall
    only difference is the red dye, yes it will damage your car if tax man gets old of you, it wil be straight to the crusher, along with you straight to court with a massive fine to re-coup tax losses by you using tax free fuel. the amount they fine you is normally a lot more than the tax you will of saved as well
    Regular Member PORKBALLS29's Avatar
    Epping
    I work in plant hire and i buy in red diesel at just over £0.50 per litre at the moment. But i can remember back in the day when it was £0.10 per litre. And yes it is only red dye added to normal derv.
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Wish i could get kerosine that cheap and the closest that get to the ground is in my heating tank lol
    Quote Originally Posted by rjw View Post
    Thankfully this is not the case, the car will not be taken away and crushed, it is just an unpaid tax
    The court will normally enforce the unpaid taxes, plus interest, plus costs, plus a fine
    However, this is very difficult for Customs & Excise to enforce, as they can only base the prosecution based on the fuel in the tank, unless they have evidence of continual use over time
    DERV has a white dye added to it
    This is an attempt to diferentiate it from Kerosene which has a blue colour
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Wasn't Kerosene used in tractors in bygone days, think they started them on petrol and once they were hot they switched over to kerosene?
    Think was also used on heavy earth moving plant?
    Norwich
    Trim : SXi
    Engine : 2.2
    Taken from C&E website
    5.1 Offences and penalties
    Offences
    You may be liable to -
    If you:
    misuse or supply oil (other than fully duty paid fuel) for use as fuel in a road vehicle
    misuse or supply rebated kerosene for use to propel an excepted vehicle or as fuel in an engine (other than to provide heating) or
    mix any rebated or duty free oil with any oil on which no rebate has been allowed.
    civil penalties under Section 9 of the Finance Act 1994 or an Excise wrongdoing penalty under Schedule 41 of Finance Act 2008.
    your vehicle (or engine) being seized and forfeited.
    if your conduct involves dishonesty, a penalty of up to 100% of the duty evaded may be imposed.
    If you:
    remove any designated chemical marker of dye from any fuel or
    add any substance to the fuel to prevent the chemical marker from being identified.
    the goods and oil may be seized and forfeited.
    If you obstruct one of our officers inspecting premises or vehicles or testing or sampling oil.
    an unlimited fine or imprisonment for up to two years, or both.
    In the more serious cases involving dishonesty criminal action may be taken, and the offender can be fined an unlimited amount or imprisoned for up to seven years, or both.
    Better off using veggie oil
    Jul 2009
    london
    i believe most damage is caused if you are using red diesel that has had the dye removed. Basic process involves using filtration materials and sulphuric acid to mask the marker dye, but unfortunately, it is the acid damages the engine / injectors.
    The golden rule is to always buy your fuel from reputable forecourts. There have been cases where smaller independants have purchased supplies cheaply from a fuel launderer only to find that the fuel was cheap for a reason.
    belfast
    Quote Originally Posted by kabooboo View Post
    yes,ive heard of places adding home heating oil to it which doesnt lubercate the pump as much as it would like hence why fuel pumps are going...
    Regular Member benny's Avatar
    Feb 2006
    dudley
    the problem with "red" is the type of people that sell it and where it is stored that normally leads to problems not with the fuel but the contaminats that get into it ...there was a roumer they were going to stop doing red and let every one use "white" and people that are legally ok to use the old "red" could claim the duty back....
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. V POWER DIESEL Vs DIESEL
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2009, 21:22
  3. BP Ultimate Diesel vs Morrison's mucky Diesel
    By Big Knox in forum General Chat
    Last Post: 31st March 2009, 13:11
  4. Shell Diesel Extra Or BP Ultimax Diesel
    By tonyx420 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 13:25
  5. 2.0 Diesel
    By cp123 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2006, 23:50
vectra cdti red diesel
red diesel 1.9cdti sulfur content
can u put red deisel in a vectra sri cdti
red diesel in vectra c
vectra c red diedel
can a vauxhall insignia run on red diesel
can I use red diesel in a vectra c
vectra red diesel
using red diesel in a vectra
vauxhall vectra 1.9cdti red diesel
