Thread: Tuning box
    Regular Member russ1969's Avatar
    Worthing
    Default Tuning box
    Been given a tuning box that is from abrieb chiptuning.
    A few things i would like to know if anybody can help please
    1. As anybody else used one of these?
    2. Where does it fit?
    3. How much more performance will i get?
    4. Is it ok to use on my car and what could the after effects be?
    5. Could this knacker my DPF up?
    My car is a 1.9cdti 150 auto elite
    EVERYWHERE
    If you remove the engine cover you will see a silver tube with four high pressure pipes leading into the front of it. At the right hand end of that tube you will see a connector. You disconnect the connector and then connect the tuning box in series between the male and female parts.
    P.S. Make sure you attach the box the right way around. The connectors at each end are very similar.
    http://www.vectra-c.com/forum/attach...9&d=1279277448
    You should get another 30bhp and 50ft/lbs torque.
    If your engine transmission has any parts that are marginal, the tuning box will make their presence known to you!
    As for the DPF...personally I wouldn't recommend a tuning box with a car equipped with one of these.
    Worthing
    sorry to ask another silly question but does anyone know if my car does have a DPF?
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    If it's an Auto or Estate, then most likely.
    EVERYWHERE
    Most tuning boxes are usually adjustable. Try adjusting the box to a minimum setting that you are happy with. By doing this you will hopefully not create too much extra soot for the DPF to cope with. Do not adjust it to more than its factory setting.
    Worthing
    There doesn't seem to be anywhere to adjust it unless I open it up and I don't really want to do this
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Thumbs up
    leave it alone then matemost of them undo on the end(two self tapping screws) but if it feels ok with it how it is ............just leave it
    Worthing
    I haven't put it on yet
    The last thing I want to do is put it on and then find out it knackered something up and face a big bill
    It's not new and I don't know the history of it and can't even find out wot extra it will give me?
    So I don't know if it's already been turned up or down
    Last thing I want is to go from running great to start having issues
    Worthing
    bump
    Regular Member badback's Avatar
    Runcorn
    I've recently put a box on mine mate, I too have a dpf, I bought the box more for the mpg than the power, but it is nice to blow it's tubes once in a while. It's improved the turbo lag a hell of alot, If you do put it on I'd check what setting it's on first as it could well be on the top one. My mpg has improved aswell.
  1. TDI tuning - tuning box thoughts so far...
    By nichols120 in forum Diesel Engine related
    Last Post: 4th February 2012, 20:48
  2. tuning box or not to tuning box that is the question
    By dazzer t in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2010, 21:47
  3. need help with tuning box
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2010, 19:49
  4. Caterman/T-Tuning Tuning Box for 1.9CDTi 150 (Z19DTH)
    By CHRISRi in forum Parts for sale
    Last Post: 25th May 2009, 18:49
  5. Diesel Tuning UK Tuning Box FOR SALE CDti 150
    By sshooie in forum Parts for sale
    Last Post: 1st April 2008, 16:49
