Thread: Been playing again...
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Been playing again...
    Just fitted my strut brace Im unhappy with the amount of washers used to space it but happy with the results! Pics when i find my cable.
    Next mod:
    Get new wheels on but i have a question about 'wobbly' bolts. I know they are safe and all that rubbish but seriously, how do you use them? IE. do i fit the wheel then the bolts as normal or do i line it all up then tighten them a bit at a time?
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    Just out of interest how many washers you use and what size? I fitted mine without but dont like how much it sits on the brake res
    cheers
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    i use wobly bolt on mine.. every winter but they only can be used to change 1 size.. eg. 108 to 110 or 110 to 112 mm.
    Engine : 1.9 CDTi
    The spigot rings will centre the wheel.
    Then just do the bolts up. The wobblie bolts have a washer on them that will sit in the wheel hole.
    Aug 2010
    Stoke on Trent
    Jul 2006
    Northampton
    Trim : Sri
    Quote Originally Posted by 0uT1aW View Post
    cheers
    I fitted it with 2 washers and a spring washer but still didnt like how much it sat on the brake res so have 3 washers and 2 spring washers each bolt. I think i might remove one of the spring washers tho.
    Quote Originally Posted by kenp View Post
    Quote Originally Posted by lee gsi View Post
    So it is fit them as normal then
    Quote Originally Posted by jimbojetset View Post
    Sorry cant find cable but will continue looking tomorrow
    Engine : 2.2 Direct
    Quote Originally Posted by Danwells72 View Post
    Yep
  1. just been playing
    By bobssignum in forum Detailing and Car Care Discussion
    Last Post: 16th September 2008, 09:48
  2. just been playing with my wii!!!!
    By BIG NEIL in forum Games Room
    Last Post: 15th September 2008, 14:24
  3. been playing
    By PeteRs in forum The 'Off Topic' room
    Last Post: 11th February 2008, 15:54
  4. No one playing
    By Steel in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2008, 21:38
