Thread: Recommend a torque wrench
    swansea
    Default Recommend a torque wrench
    Any suggestions for a wrench less than say £30. I have heard that some are easier to use than others. Not looking for the cheapest.
    Regular Member tgbo's Avatar
    Nov 2010
    stirling
    is it for personal diy or work use bud ? if its for work use it will need recalibrated every year so you may be able to scam one out of your bosses
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    As above, depends what use you intend putting it to, everyday tool or occasional.
    swansea
    Home use only.
    Jan 2010
    Middlesbrough
    halfords have a sale on, you might pick one up in there. Otherwise try machine mart
    Regular Member VFR's Avatar
    North East
    The torque wrenches in Halfords are not included in the sales, they do however get very good reviews for accuracy and reliability. However they are quite a bit above your £30 budget @ £70 or £80 depending upon the range that you need.
    With a cheaper one that may not be as accurate it may be that you'll end up overtightening something with the associated cost of fixing whatever breaks and end up worse off.
    I guess it's a case of how often you feel you are going to use it and to whether you can justify the extra cost.
    Nottinghamshire
    Argos do one for £20. OK for occasional home use. Maybe not that accurate, but much better than guessing.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Rolson ones on E-bay with various ranges and either 1/4", 3/8" or 1/2" drives.
    Regular Member sheepish's Avatar
    Yorkshire
    Hi,
    I bought this one for heavy stuff (1/2 drive):
    http://www.autoexpress.co.uk/product...per_3001a.html
    And a Halfords 8-60nm (3/8 drive) for the for lighter stuff. This one was a lot more expensive, but I bought it because it got good test results for accuracy (as mentioned above) and at the time I was mostly going to use it on my bike where everything was made of alloy so more likely to strip threads, etc...
  1. Torque Wrench:WHICH IS THE BEST ONE TO BUY?.
    By felixx in forum Engine & Drivetrain
    Last Post: 8th February 2011, 11:02
  2. Torque Wrench
    By Marky in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2010, 16:09
  3. Torque Wrench
    By arkhan78 in forum General Chat
    Last Post: 20th September 2010, 22:35
  4. Torque wrench..
    By macdad in forum General Chat
    Last Post: 11th December 2009, 09:04
  5. Torque Wrench
    By bgm46 in forum General Chat
    Last Post: 8th June 2008, 22:07
