Results 1 to 3 of 3
Thread: Vectra C-03 reg, -2.0 dti 16(y20dth)
    Dec 2010
    Lyneham
    Default Vectra C-03 reg, -2.0 dti 16(y20dth)
    Hi i have a Vectra C-03 reg, -2.0 dti 16(y20dth), she cant start ive brought a few guys around to look at but to no avail they couldnt help me,she only did 87,676k. now she is just sat there I cant wait to get her on the road again. the other guys who nosed around said there is totally no pressure on the engine. however. all i need is to get someone to tell me how to fix the problem , do i need to get another engine or fix the one that in the car and dont want the cost to be out of hand aswell. approximately how much can i spend ..
    one other thing I need an experienced diesel mechanic experienced with vauxhall vec around area lyneham,swindon etc. PLIZ HELP GUYZ U ARE EXPECTS IN THIS
    Regular Member mozzer99's Avatar
    bristol
    The most likely common problem is the fuel draining back to the tank due to an air leak in the diesel pipes, the pump then can't pull it back quick enough to make it run.
    Take the top off the fuel filter - quickly - and see if it is full. If not the fuel has drained back. Top the filter back up brim full and put the top back on quickly. Ensure you have plenty of fuel in the tank.
    There are many posts on here about replacing the leak off pipes (easy), at worst the injector seals (hard).
    I would try to start the engine with easy start or brake cleaner into the inlet manifold (take off the rubber inter cooler hose). You need two people for this - run it for 10 - 20 seconds on the easy start (vary the amount sprayed to change the speed, not too much) until the engine note changes as fuel reaches the injectors. If this works and the engine then runs well, it is the air leak described above.
    If fuel does not come through then you need more help and fear the injection pump has failed/immobiliser.
    bristol
    posted in error
  1. Vectra C Y20DTH 2003....is this an ECU problem??
    By Acebob666 in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2013, 17:22
  2. Vectra c y20dth 2002 dti 2.0 remap and de cat
    By richardkay007 in forum Diesel Engine related
    Last Post: 4th May 2012, 00:17
  3. My Vectra Y20DTH
    By cristi.grigore in forum Introduce yourself.
    Last Post: 2nd April 2012, 16:06
  4. ELM327 Reader Vectra C Y20DTH 2.0 DTI 2002
    By richardkay007 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 19:41
  5. Y20DTH 2.0 DTI 2004 Vectra - Increase BHP?
    By Leviathan in forum Tuning
    Last Post: 23rd September 2008, 23:00
