Thread: can anyone recommend a multimeter?
    Regular Member sheepish's Avatar
    Yorkshire
    Question can anyone recommend a multimeter?
    Hi All,
    Can anyone recommend a good but inexpensive multimeter that can read low voltage AC?
    The ABS and traction control light came on today (on the wife’s car) and I'm assuming/hoping it's only a wheel speed sensor (?). The Haynes manual recons the sensor should give you between 1.5 and 2 V AC when you spin the wheel. My existing multimeter only has a 750 and 200 options for AC and even on 200, I get nothing from either front sensors... and I'm assuming they haven't both managed to fail at exactly the same time...
    Regular Member scottyd's Avatar
    paisley
    check resistance of them 1st mate
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    AC the only area this is present is in the alternator which the has a diode pack. Every thing derived from the battery is DC.
    Both Screwfix and Maplin sell multimeters they will have both AC & DC ranges on them.
    wirral
    60 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    http://www.amazon.co.uk/Draper-60792...3753773&sr=8-1
    thats the one i use :thumbs:
    can prob pick something similar in halfords, maplin etc
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I can most certainly recommend one
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 74000
    Just make sure you get one with an Auto Off function, mine doesn't and has silly 6v batteries. The amount of times Ive found it on and the battery flat.........
    Regular Member Exclusive BV's Avatar
    West Midlands
    I you want to measure low voltage AC then i recommend the UT50A Digital meter (code N77CB) from maplin. this covers 200mv to 750 v AC & DC. (£19.99) There are lots more expensive one in there but this does the basics nicely for a good price.
    Curiously enough they also stock an automotive multimeter. This unit does not measure AC Current. I was under the impression that the alternator dealt with AC to a point as said above
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI160
    Year : 2012
    i guess they are all much of a muchness, just check if it can do the readings that you need. mine's an old rapitest, still works fine.
    Nottinghamshire
    As above, you need DC to check wheel speed sensors. The current rises and falls as each tooth on the cog passes the sensor (looks like a sine wave but with a square waveform when seen on an oscilloscope) but it is not actually AC. You may find this hard to see on a digital multimeter as it alternates quite fast.
    What error code do you get? There a quite a few relating to the wheel speed sensors (voltage issues, missing teeth on the cog, etc.) and so will help point you in the right direction as to exactly what the problem is.
    Also check the wiring plugs for the wheel speed sensors. These are at the back of the wheelarches behind the suspension strut and they seem a bit prone to leaking on early cars especially in wet weather. Take them apart and if they are showing signs of leaks or corrosion of the pins, dry them out and clean them up, then wrap them in insulating tape before refitting in the brackets.
  1. What multimeter
    By SEANYboi in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2013, 23:30
  2. Digital auto ranging multimeter Qs
    By SlowCoach in forum General Motoring Chat
    Last Post: 8th January 2013, 19:27
  3. MAF test results(multimeter)
    By justin32 in forum Engine & Drivetrain
    Last Post: 20th November 2011, 17:59
  4. Multimeter
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2011, 21:03
  5. Multimeter setting for power drain?
    By rushy in forum The 'Off Topic' room
    Last Post: 6th March 2011, 15:12
