Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: 3 & 2 Button Flip KEY
    Jul 2009
    NEWPORT
    Default 3 & 2 Button Flip KEY
    I think i've solved a problem that most of us have had while getting a new key ? as we all no the ones that we get from the bay cannot be re-programed as the transponder cannot ! be changed well i have come across a site and the listing is below
    3 Button Key
    Supplier References • OE Reference Delphi G3-AM433TX v1.0 93.187.511
    Applications • Vauxhall Vectra C 2002 - 2008 • Vauxhall Signum 2003 - 2007
    Technical Specifications and Other Information • Transponder ID46(PH20) • Flip Key H Series Vectra C • Blade Type HU43
    2 Button Key
    Technical Specifications and Other Information • Transponder ID46(PH20) • Flip Key Z Series Vectra C • Blade Type HU100
    The transponder i have seen on the site is as listed below
    Applications • Vauxhall / Renault
    Technical Specifications and Other Information • ID 46 IC Board to put on board of remote
    They are charging £5 plus vat for the Transponder what do you guys think is it worth getting one and try it ? Or has anybody tried one
    Thanks in Advance
    Jul 2009
    NEWPORT
    Just a quick update i have also found them on ebay motors got 2 on order at a cost of £10.01 inc shipping so if anybody is interested i will keep you posted
    Jul 2010
    Warrington / Liverpool
    Are you getting two new keys for £10 or just the boards for inside it?
    Jul 2009
    NEWPORT
    Quote Originally Posted by UncleMelon View Post
    I'm getting 2 transponder chips they will have to be placed onto a 2nd hand board I've got a spare key from the bay then I should be able to programe it for my car as 2nd hand keys won't re-programe by doing this a key should be easy to re-use so it would cost about £20 for a working key as long as you have a car pass and the software
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    i have the software to do it 3.2 but not sure if it will work, if you want to come to my house in near bridgend your welcome to try and give it a go
    Regular Member Exclusive BV's Avatar
    West Midlands
    Sorry for the mini hijack but I want to change the key on the wifes 05 zafira to a flip key.
    Will the circuit board fit from the old type into the new?
    13 Post(s)
    Is the current fob like the Vectra-B / Astra-G one?
    If so, does this help?
    http://www.yellowdawg.co.uk/flipkey/Untitled-1.html
    http://www.andi.mat.btinternet.co.uk...rum/keyfob.pdf
    Regular Member vectraboyy's Avatar
    Quote Originally Posted by davidjameswest View Post
    You can do it off opcom.
    Be very interested if it works as i don't have a spare.
    Jul 2009
    NEWPORT
    As you can see this is the board with the transponder
    I have taken the transponder from the board
    The transponders are on the way from the bay they will be another 10-14 days due to shipping so i will keep you posted as soon as they have arrived
    Jul 2009
    NEWPORT
    Cheers ive got the software thanks anyway
  1. 3 button non flip key internals fit straight into a flip key shell???
    By Jow20 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2011, 01:44
  2. 3 button flip key
    By bembo449 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 18:54
  3. vauxhall 3 button flip key
    By kdadidog in forum General Chat
    Last Post: 26th January 2010, 16:19
