Thread: Fault codes..One I was expecting
    Aug 2009
    herts
    Default Fault codes..One I was expecting
    Been having the spanner light appear during driving the first few mins on these cold mornings, and assumed it would be the glow plugs faulty as after a few mins driving the spanner light would go out - no driving related issues at all.
    Fault codes
    P0380-08 Glow device General Error - glow plugs need replacing then? Can someone confirm that is all this fault is? On a diagnostic check on output tests - glow time relay test it says glow time relay inactive 12v, this i assume is because the car was already warm?
    Also didnt expect;
    U2139-00 Canbus no communication with CIM (steering control module) - eh? anyone please?
    and
    B3794-08 Switch cruise control circuit malfunction. This will be accepted as my cruise control has suddenly switched off on occasions when driving on motorway in one gear, set speed. Easy fix?
    Many thanks in advance for your help.
    Colin.
    Huddersfield
    Ignore the middle one I got that and several similar on mine. VX advise to disregard unless you do gave problems.
    Aug 2009
    herts
    sorry about op com comments, wish to retract if could.
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by hertscol View Post
    Done
    Irmscher Insignia CDTI 130
    Regular Member Innes's Avatar
    Plymouth
    Yeah dont worry about the Canbus error reading. It just means it failed reading that certain part of the scan. It doesnt indicate a problem.
    Remeber PRESENT - means the fault is currently there at the time of scan.
    NOT PRESENT - Means its an old stored code and at the time of the scan it wasnt present (although it may still be an intermitant problem).
    Bristol
    Vehicle : CDTI 150
    Probably the clutch pedal spring. Spring gets weak and does not support the weight of the pedal this activates the clutch pedal switch so the ECU thinks the clutch is depressed and therefore will not allow cruise control selection.
    With a 'suitable diagnostic program', scan the ECU, select measuring blocks, then run down the drop down menus til you find the clutch and brake pedal switches (2 brake ccts to check). With ign on should all read inactive, when depressed should change to active.
    If the switches change between active/inactive with very very light (feather like) pressure then spring is u/s.
    If either switch reads active when not pressed put your foot under the pedal and lift the pedal, if switch then goes inactive probably spring if remains active probably the switch.
  1. fault codes
    By GSi-Col in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2012, 00:00
  2. fault codes
    By bigcarp1953 in forum Engine & Drivetrain
    Last Post: 13th December 2010, 15:04
  3. Fault Codes?
    By countduckula55 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd October 2010, 21:29
  4. 2 fault codes
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 12:49
  5. Fault Codes
    By cosmic in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2009, 08:19
