Have any of you fine people carried out a steering column change?
My 2002 DTI SRI 2.2 has gone very loose, it can be pulled up and down and moved side to side .
Have checked both steering joints on column and both are tight with no play . There is no lose of control over driving wheels , it just seems play is in column.
Took top steering shroud cover off removed speedo to get better look and it appears to me that the adjustable steering wheel mechanism is not gripping propley .All bolts holding column on are tight.
Ebay has columns for about forty pounds so not too bad , to me it appears to be a resonable job to change after all plastics and airbag is removed.
Any advice would be gratefuly recieved .
