Likes Likes:  1
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Vectra C steering Column Change.
    Regular Member Suffolk Boy's Avatar
    Apr 2008
    NEWMARKET
    Default Vectra C steering Column Change.
    Have any of you fine people carried out a steering column change?
    My 2002 DTI SRI 2.2 has gone very loose, it can be pulled up and down and moved side to side .
    Have checked both steering joints on column and both are tight with no play . There is no lose of control over driving wheels , it just seems play is in column.
    Took top steering shroud cover off removed speedo to get better look and it appears to me that the adjustable steering wheel mechanism is not gripping propley .All bolts holding column on are tight.
    Ebay has columns for about forty pounds so not too bad , to me it appears to be a resonable job to change after all plastics and airbag is removed.
    Any advice would be gratefuly recieved .
    Administrator plasma's Avatar
    On the Forum
    556 Post(s)
    Engine : 150
    Mileage : 74000
    you havent knocked the lever which lets you adjust the steering column up/down left/right have you?
    Apr 2008
    NEWMARKET
    Quote Originally Posted by plasma View Post
    How do you mean?
    Ely, Cambridgeshire
    63 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Under the wheel is a lever you pull it down to release it to allow you to move the wheel to your chosen position, then lock it back up again to hold it in place. It does sound like you've just knocked that open.
    Edit: just noticed you mention you've checked the adjustable steering mechanism, so I guess it's not that then.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Is the reach/rake lock mech not adjustable in some way ?
    Apr 2008
    NEWMARKET
    It does not seem to be although I could be wrong. I couldnt see any obvious part on it when I had the cover off . It seems that its just not gripping inside propley, I dont know how it works but am guessing its some sort of plastic sleeve.
    Thanks for replys so far.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    Quote Originally Posted by Suffolk Boy View Post
    the adjuster is underneath the column
    Apr 2008
    NEWMARKET
    Quote Originally Posted by markj23 View Post
    Yes I know .
    Aug 2010
    Luton
    I would say undo it move wheel to limits a few times then re tighten a few times in different positions see if it sorts it it might be wear on the adjuster cant see it being column
    Apr 2008
    NEWMARKET
    I will try but it appears to me that the adjuster is not a separate item from the column so if the adjuster is knackered I will have to change the whole lot.
  1. Steering column help please
    By TopRod in forum Vectra C / Signum Troubleshooting
    Last Post: 20th April 2012, 11:08
  2. Steering column movement.
    Last Post: 30th June 2011, 13:14
  3. changing steering column controls vectra c 2003
    By morgan1664 in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2011, 15:15
  4. steering column problem
    By veiluoks in forum Engine & Drivetrain
    Last Post: 4th October 2009, 16:19
  5. steering column
    By robjones in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2008, 18:32
vectra c steering column movement
vectra c steering column diagram
vectra c triangle bit in steering column
vectra c rake movement
what size is the spline on a Vauxhall vectra c steering wheel column
Vauxhall Vectra C 1.8 Petrol Adjustable Steering Column 2002-2009 diagram
