Thread: Help needed cdti broke down urgent
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default Help needed cdti broke down urgent
    Hi guys was driving home last night and the last 50 miles the car all of a sudden started jerking best way to describe it was like it was running on 3 cylinders
    The whole car shook if I pressed the throttle and on tick over sounded very lumpy and rattled
    I have had no eml and no fault codes what could it be I'm thinking injector or the wiring but surely this would bring up car and spanner light
    I am goin to check no3 wiring now but I have no idea could it be fuel pimp or not
    kings lynn, norfolk
    Just beenout and wiggled the plug it's cured it so I have cable tied the plug on and it's running ok a trip to Vauxhall now then to get the field fix kit
    Administrator plasma's Avatar
    On the Forum
    541 Post(s)
    Engine : 150
    Mileage : 74000
    kit should be about £14 or so, not a bad job to do.. make sure you make the join further around the loom otherwise fitting the casing back around the wiring can be tight.
    Aug 2009
    sheffield
    the dreaded 3rd injector plug again. this should be a recall,come on vx . use the thick wires.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Sounds like the 3rd injector loom fault just from your first post. It never really puts up the EML light.
    Gazza4
    jilava
    Winnie, you should really replace all of them. Last summer I had problems with the 4th injector plug, so I replaced all and it's been fine since. The new blue plugs fit really well and snug compared to the yellow ones.
  1. urgent help needed?
    By webber446 in forum Engine & Drivetrain
    Last Post: 11th January 2012, 14:30
  2. Urgent help needed
    By jlock in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2010, 14:12
  3. Urgent- vx part number needed -suction control valves v6 cdti
    By rickyhopkins in forum Engine & Drivetrain
    Last Post: 16th April 2009, 10:45
  4. Broke down CDTI 150 - Needs new engine !
    By as5606 in forum Engine & Drivetrain
    Last Post: 27th February 2008, 17:28
  5. broke vectra 1.9 cdti
    By p.nut in forum Engine & Drivetrain
    Last Post: 23rd January 2008, 22:17
