Results 1 to 2 of 2
Thread: ident code
    Dec 2010
    Corby Glen
    Default ident code
    Does any one no how to find the ident code for the CIM??
    I have a 2.2 sri 2002.
    Many thanks
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    behind you steering wheel you have the key barrell, the this is part of the CIM. Move the steering column to its lowest position. You will need to prise off the screw covers to remove the shroud that fits around the CIM unit, there is also a circular trim panel around the key barrell,, once oyu have this off you will see the number on the top right hand side aboc ethe ignition key barrell. carefull use of a few small screwdrivers should be enough to expose the CIM. The part number of the CIM id printed ob the top left of the module.
    picture for illustration purposes only:
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...item3363a47cdc
  1. AFLs fitted? Whats your fusebox ident code?
    By Caveman_nige in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2012, 16:58
  2. Does CIM need tobe same ident.
    By krazylegz in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2012, 17:51
  3. How do i find out the ident code for my gsi?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2012, 09:14
  4. GiD Ident Codes
    By vxpenfold in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2010, 00:19
ident code vectra
