Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: 3.2 auto
  1. #11
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by Venkman View Post
    well its not the end of the world £139 all in from the dealer.
    For £139 it sounds like you're just getting a "basic" fluid change which, according to VX, is scheduled at 40k. Changing the ATF is no bad thing at your mileage as it will certainly help with your jerky change.
    There are other threads on here detailing the ATF change and flushing of the box. Flushing uses a lot more ATF oil than is asocaited with a simple oil change. IIRC, Dae36 has more details on the flushing .
  2. #12
    Devon
    Quote Originally Posted by pinnacare View Post
    I think it's a radiator seal that will need to be changed, it separates the ATF from the coolant. Renew the ATF in the process, price is good.
    I would double check what they are actually doing as £139 will not cover the replacement of radiator and labour by a main dealer. As gtr1000 has said for this money it sounds like they are just changing/flushing the ATF which will not stop any failing of the ATF seals in the radiator and leaves you in exactly the same position as you are now minus £139.
    If they are just changing/flushing ATF then this not correct and as far as I'm aware the radiator is sealed and not serviceable and you cannot fit new seals inside it. The only way to stop any potential problem happening is to fit a new radiator, or fit a seperate oil cooler!
    To double check their 'replacing the seals' story ask them for the actual part numbers of the seals they are replacing - I think they might struggle a little bit!!!
  1. auto wipers, can you fit auto headlights?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2011, 11:32
  2. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  3. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  4. Auto Dimming Mirror/Auto Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 21:42
  5. Vectra 1.9CDTI 150 Auto v 2.2Direct Auto
    By mattr in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2007, 19:16
