Results 1 to 2 of 2
Thread: Fault code 1901 and limp mode ?
    Dec 2010
    Hanworth
    Default Fault code 1901 and limp mode ?
    Stripped down and cleaned egr valve which is now ok but after driving 2 to three miles car goes into limp mode. After turning off ignition and re-starting it does the same again last plug in i had came up with P1901 pressure sensor differential too high, is there a simple fix for this ?
    Bristol
    Vehicle : CDTI 150
    1901 normally relates to the DPF. The sensors are connected either side of the DPF and the difference between pressures informs the ECU of the state of the DPF.
    Excessive soot which can block the EGR can also lead to soot build up in the DPF.
    Simple fix may mean driving the car so the ECU can perform a regen.
    Engine has to be at normal operating temp then run for about 20 mins over 2500rpm
  1. Power loss like limp mode no code/light
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 19th March 2013, 10:27
  2. Limp mode on my 2.0 dti and fault code is p0243.
    By dazza2393 in forum Engine & Drivetrain
    Last Post: 20th September 2012, 20:57
  3. stuck in limp mode p 1604 ecu code
    By christopher8079 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2012, 16:07
  4. Fault code and limp mode
    By paulvectrac in forum Engine & Drivetrain
    Last Post: 7th February 2012, 20:58
  5. Anyone got a code reader? My car is in Limp mode... :(
    By wingz123 in forum Vectra C / Signum Troubleshooting
    Last Post: 29th March 2011, 00:40
car code 1901
