Thread: really annoying and potentially costly problem?!?!?
    Regular Member AKeeNShoT's Avatar
    South Shields, T&W
    Default really annoying and potentially costly problem?!?!?
    this has just happened today as i noticed it at tea time, the leds on the cluster, the heater controls and the sefeguard switch, remain illuminated all of the time. they used to come on with the side lights/lights, and when the car was remotely unlocked. however now they just stay on.
    also, the dimmer switch, only adjusts the light output on the TID, the cluster displays and the door switches. the leds in the clocks and the leds in the heater controls remain at the same brightness.
    now the problem starts here, i noticed this at tea time, i mostly use the car on a night, as i work night shifts, and have only noticed it today at dusk. i havent used the car since then, and already can feel the battery draining, like it turned a few too many times before firing.
    any ideas as to what may be the problem, or at least things i can check???
    any and all help is greatly appreciated.
    atvb
    michael
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Have you had and SMD's changed in the past?
    South Shields, T&W
    Yeah mate, full blue conversion! Is that something to do with it?
    South Shields, T&W
    ive had them fitted now for 9 months, with no problems. i also noticed that the little lcd screen in the tachometer has leaked, noticeable when a car door is open?? could this be linked in someway?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Possibly. It might be worth checking that none of the solder has crossed onto another track.
    South Shields, T&W
    I don't think that's the case, as I didn't do these myself and like I say, they were working fine! There must be a simple yet logical explanation to why this has happened!?!?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    You could take each component out and test each PCB as a unit to narrow it down or even eliminate it all together. Start with the clocks as you mentioned the little LCD. Although your best asking one of the professionals on the site what exactly to test.
  1. Annoying problem
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2012, 15:51
  2. annoying problem
    By shoota70 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th October 2011, 21:21
  3. 2.2 annoying problem with Auto
    By colinstar in forum Engine & Drivetrain
    Last Post: 28th March 2011, 13:06
  4. Annoying Indicator Problem
    By laingyc in forum Electrical & ICE (including SatNav)
    Last Post: 13th April 2010, 13:59
