Thread: 56 Plate vectra 150 CDTI running probs !
    Dec 2010
    Hanworth
    Default 56 Plate vectra 150 CDTI running probs !
    Got flexi pipe replaced on front of exhaust as it was leaking, had new flexi welded in at power flow dealer. Now car goes into limp mode after driving about a mile or so any ideas, have also just stripped and cleaned egr valve and fitted modded gasket as egr was clogged up and car started chugging real bad. So any ideas on limp mode and possible other power loss probs/fixes
    Aug 2010
    Stoke on Trent
    You need to get the codes read on your car....
    Dec 2010
    Hanworth
    had plug in done after flexi pipe done and it come up with dpf filter pressure too high, then i drove through fault and it reset was ok for over a month and runnin like new. Started playin up again tho but plug-in didn't come up with any codes this time
    preston
    i'd be tempted to say recheck your egr adn boost sensor
    but since you already had dpf problem then maybe its regenerating
    try taking it for a good run but keep the revs over 2500 for about 30 minutes
  1. Vectra cdti 1.9 Sri 120 - 58 plate
    By allysri120 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2012, 09:20
  2. Vectra CDTi Sri (150) 56 Plate
    By Phil-W- in forum Cars for sale
    Last Post: 12th February 2011, 11:30
  3. vectra 1.9 cdti 150- running cold
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 19:10
  4. few probs vectra 2006 cdti 150
    By ps3chris in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd July 2009, 23:49
  5. Vectra C 05/55 1.9 SRI CDTI Known Probs Or Lookouts?
    By scottishcruiser in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2008, 23:27
