Thread: How2 for CDTI 120 thermostat change?
    Regular Member westonprawn's Avatar
    Jul 2009
    TELFORD
    Smile How2 for CDTI 120 thermostat change?
    Just wandered if there was a how2 knocking around for this as can't see one? any tip's etc welcome as I need to change mine this weekend
    Cheers, Justin
    Regular Member kantimpalo's Avatar
    Feb 2007
    Spain
    In the Spanish VectraC forum you can find a Howto for change this thermostat
    http://www.zonaforo.com/vectrac/viewtopic.php?t=9395
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Quote Originally Posted by kantimpalo View Post
    Need to be registered to use that site.
    Nottinghamshire
    Quote Originally Posted by RobW View Post
    Register at http://www.zonaforo.com/vectrac/prof...?mode=register.
    Google Chrome makes a good job of translating the registration process into English. Hopefully it is as good with the actual article...
    PRESTON
    120's can be a pig to change the stat. best advice i can give is get a vacuum pump gasket from the dealers and remove the vac pump before starting to change the stat. it gives you tons of room to work and is easy, 3 bolts, to remove. Also, you will need to loosen the egr cooler, as i recall there are a couple of bolt holding it to the back of the block. The cooler needs to be loosened in order to remove the stat.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Quote Originally Posted by James24 View Post
    Unfortuatley they won't accept email address with:-
    yahoo.co.uk
    hotmail.com
    gmail.com
    I've just tried registering and had no joy what-so-ever Shame as I am going to be doing the thermostat when it warms up a bit, so a how-to would have been perfect
    Jul 2009
    TELFORD
    Quote Originally Posted by barney490 View Post
    Cool just what I needed cheers
    Justin
    Regular Member phe's Avatar
    Feb 2006
    Guadalajara (Spain)
    Vehicle : Vectra OPC
    Engine : Z28NEH
    Mileage : 120.000km
    Quote Originally Posted by Damo77 View Post
    yahoo.co.uk
    hotmail.com
    gmail.com
    If you need registering, contact to me for private message
    Unfortunately, the restrictions are very high to avoid "boots" registration.
    can register with any false mail (xxx@agmail.com for example), while communicating their correct mail and you desire to sign to forovectrac@gmail.com
    sorry
    lincolnshire
    these are a **** to do , did one on the XP for the previous owner , the pipe for the EGR gets in the way if memory serves me right ??
  1. how2 change gearbox oil on 150 bhp 1.9 cdti
    By hippo in forum General Chat
    Last Post: 28th November 2012, 01:26
  2. cdti 120 cut out after thermostat change
    By seddo in forum Engine & Drivetrain
    Last Post: 4th November 2012, 17:33
  3. CDTI 120 thermostat change
    By westonprawn in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2011, 19:33
  4. thermostat change cdti
    By dazza2393 in forum Engine & Drivetrain
    Last Post: 9th January 2011, 23:57
