Results 1 to 10 of 11
Thread: How to remove the swirl actuator?
    Sep 2010
    Netherlands
    Post How to remove the swirl actuator?
    Hello,
    I got a problem with the swirl valves (doesn;t work right now).
    And i hear the actuator moving but i don't see the swirl valve moving.
    I read the this and it say's that i have to remove the actuator.
    How can i do that?
    Best regards,
    Regular Member farley2708's Avatar
    antrim n.ireland
    Is the rail lying on it's side? The 3rd one from the left is the 'acuated' flap,mine was lying on it's side,saw the thread on here for a £1 fix so went for it.it worked so far so good
    Market Harborough
    Quote Originally Posted by farley2708 View Post
    Engine light came on on my 55 plate 58K Signum 1.9 Cdti. I thought it would be the EGR valve but when I opened the bonnet the swirl valve bar is on its side.
    Do you have a link to the repair please?
    ETA: Found it: http://www.vectra-c.com/forum/showthread.php?t=33511
    Administrator plasma's Avatar
    On the Forum
    556 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by genesisfm View Post
    Hello,
    How can i do that?
    Best regards,
    Providing its the 150bp on the actuator itself is a little plastic link rod which connects to the underside of the inlet manifold which then turns valve no3. Best access to it is to remove the oil seperator and vaccum box although removing EGR/Throttle body will improve access.... There is a how2 on here showing a complete replacement of the manifold if you want to look with pics...
    Market Harborough
    Quote Originally Posted by plasma View Post
    Linky please? Had a search but can't find it.
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by tyre_tread View Post
    http://www.vectra-c.com/forum/showthread.php?t=121315
    On the Forum
    556 Post(s)
    Engine : 150
    Mileage : 74000
    S.E
    Is that an allegation? lol
    On the Forum
    556 Post(s)
    Engine : 150
    Mileage : 74000
    got the bruises and photo evidence....
    Market Harborough
    Thumbs up
    Brilliant! Thanks.
  1. Swirl actuator
    By carl78 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 11:44
  2. Swirl pot actuator
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 21st November 2009, 01:00
  3. swirl actuator problem
    By ziggi in forum Engine & Drivetrain
    Last Post: 30th September 2009, 03:34
  4. swirl actuator problems
    By ziggi in forum Diesel Engine related
    Last Post: 28th August 2009, 11:47
  5. Swirl Actuator Problem... or not?!
    By djr69uk in forum Engine & Drivetrain
    Last Post: 2nd May 2009, 21:18
vauxhall vectra what is a swirl actuator
