Thread: Advice please folks!
    Nov 2010
    Lincoln
    Default Advice please folks!
    Spent £300 getting the DPF sorted and re-mapped. It needs disks and pads... £200? and i though i'd snapped a spring, but i've been under the car tonight and it looks like the drive bit of the altentor housing has sheared off, knocking around in the bottom of the engine bay! Metal on metal noise and a round bit of metal that looks like a clutch. Hmmmm... What to do? Its off to the garage Wednesday to be looked at. Any idea of costs? Should i keep it?
    The motors a 55plate SRI-150 estate 105 tho on the clock. Full VXR kit, Irmscher square back box, bumper and spoiler finished with 19' snowflakes and VXR honeycomb grill. It's quick, economical and has bags of room. I'm just fed up of shelling out on motors
    Regular Member Jezzy's Avatar
    S.E
    Front disks with pads, bought from Vauxhall, £70-ish; same for rears, fit them yourself.
    Nov 2010
    Lincoln
    The brakes arent a big worry (so to speak). £200 is what VX have quoted which i 've taken with a pinch of salt. Its the sheared lump of pig iron sitting in the engine bay. Paying out, again and again is driving me crazy!
    Regular Member LADmachining's Avatar
    Hampshire
    Sounds like the crankshaft pulley has failed - a common problem. They have a piece of rubber sandwiched between the inner and outer metal hubs to act as a vibration damper. The rubber fails or debonds from the metal, and you have seen the result.
    They are about £100 to replace (part cost only). Labour shouldn't be too much - an hour maximum, as sometimes the lower cambelt pulley is fixed to the crankshaft pulley.
    Nov 2010
    Lincoln
    Cheers dude. I'll update Weds.
    Regular Member mozzer99's Avatar
    bristol
    Quote Originally Posted by Awkward kid View Post
    Could it be the alternator pulley failed (pic below)? Do you mean the pulley or a bit of the alloy alternator casting? - The alternator has a small clutch within these days, fortunately replaceable fairly easily.
    A larger clutch looking bit is the crank pulley as LADmachining says.
    Nov 2010
    Lincoln
    Well... alternator pulley it is! Part £150 + vat! Which on the plus side is still only 17.5%.
    Regular Member happypostie's Avatar
    Slough
    131 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    is that from vx . if so may be worth becoming a full member as you will then get a trade card and it may bring the price down . khalid
    bristol
    Ebay do a new alternator with a new pulley for £99!
    Also as these pulleys fail regularly there are after market companies supplying them.
    My trade warehouse (Maccess) now does a range of them.
    Nov 2010
    Lincoln
    I go pick her up tomorrow! Lets hope no more bother?!
    Uploaded with ImageShack.us
  1. urgent alternator advice please folks
    By wildchild in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2012, 21:37
  2. hi folks a bit of advice needed.
    By wildchild in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2011, 21:52
  3. Beat 675, 6.2" headunit advice plz folks
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 18:14
  4. Alloys & Lowering Help / Advice Needed Please Folks
    By pjjohnst in forum Handling & Braking
    Last Post: 21st January 2009, 19:34
  5. I need some advice pls folks!!!!
    By ACE.TAG in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2007, 21:16
