Thread: Flickering Lights
    Dec 2010
    Stockton-on-Tees
    Default Flickering Lights
    has anybody actually found a fix to the flickering lights that happen when the power steering is used when turning the wheel :S
    ive scoured the forums and cannot find a definitive answer
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Its normal.. the powersteering pulls 80 amps, out of what your car can produce, you cant do anything about it.
    12 Post(s)
    Since fitting HIDs my lights no longer noticably flicker.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 74000
    I went from a 55amp to a 70amp battery and that hasn't helped with mine, although it is less noticeable than it was.
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    I'm pretty sure someone on here said that the battery required to operate a Vectra needed 66amps although the standard ones seem to be 55? Mine flicker too mate so did my last Astra as well pretty sure its related to the PAS as previously stated.
    Dec 2010
    Stockton-on-Tees
    thanks for all the comments... its crazy that whats obvioulsy such a common fault has no real solution, you would think vauxhall would have jumped on it...
    Well it's not a fault really. It's no different from when you switch the kettle on and a lamp in the same ring may dim.
    It only happens at low speed/stopped. It's a massive electrical drain from the EPAS. Voltage drops are only to be expected.
    Engine : 2.2 Direct
    Some here in Denmark claims that it helps if you tell the UEC that your cars have Xenon.
    dont know if its tru, as i havnt tried it.
  1. Lights Flickering
    By Alan/1967 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2011, 14:20
  2. Flashing/Flickering HID Fog-lights
    By Damo77 in forum Styling
    Last Post: 24th March 2011, 11:50
  3. Lights Flickering
    By Chris SRi in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2011, 22:59
  4. Lights Flickering?????????
    By shadow-irl in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2009, 10:24
  5. lights flickering
    By mat osborn in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2008, 01:57
fix for flickering lights on vectra c
