Thread: Knocking catching noise
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    Default Knocking catching noise
    Really can't work out what it is, there is a sort of knocking catching noise coming off the passenger front wheel. Happens occasionally on full lock or other times when I straighten up. Sounds like you have driven over something and catching sort of pop rubber sound. Any ideas?
    Nov 2010
    Maidstone
    Sounds like it 'could' be one of the constant velocity joints on one of the front drive shafts.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    When stationary, moving or both?
    My first guess' would be Broken spring, knackered strut top bearing or a missing lower spring sleeve
    Jul 2009
    Bucks
    When moving, there eibach springs as well hoping to have alot more luck with those. I would of thought being a spring I would notice on the bumps which I dont. Looks like the spring sleeve is there ( not mechanically minded ) is cv joints or strut top an expensive repair?
    Getting a bit fed up with the Vectra seems one thing after another.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    CV joints are a ****** but the strut tops are fairly straight forward.
    If the noise is a constant click click click noise when driving on full lock it'll be the CV joint. If it's a clunk that only happens when you turn the steering and it's a random clunk it's more than likely strut top bearings
    Jul 2009
    Bucks
    Cheers John, rough estimate on fixing the strut top price wise? Was debating throwing in the towel and getting an Astra coupe.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    I'd personally have both sides done so, 20 quid a side plus about an hours labour
    Jul 2009
    Bucks
    Just an update, they couldn't find nothing maybe just some dirt could of gotten into the sleeve, so guess just play it by ear.
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    i had the car to a mate of mine today, who is a vx mechanic he said the same thing he said it is just all the salt and muck on the roads, best thing to do is remove wheels and grease or wd40
  1. knocking noise
    By 150cdi in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2010, 19:20
  2. knocking noise
    By winnie2457 in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2010, 21:06
  3. knocking noise
    By adfrodsham in forum Suspension, Wheels & Brakes
    Last Post: 26th February 2009, 14:25
  4. Help knocking noise
    By mickeyc in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2008, 21:51
  5. 1.8ls knocking noise-help!
    By bri.gsi in forum Engine & Drivetrain
    Last Post: 17th January 2008, 18:25
