Thread: sludge in oil filler cap!!!!!!!!!!!
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default sludge in oil filler cap!!!!!!!!!!!
    help! just checked my oil and i had a large amout of sludge in my oil filler cap! this is normally head gasket is it not? the car was sitting for 3 months or so without running so could it be just condensation built up and mixed with the oil? i only got a 1000 mile 28 warrenty so the sooner i could get this diagnosed the better please help!!!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It's normal on the 3.2 mate, it's because of the oil filler extension. Take the extension off by twisting it and put the cap straight onto the cam cover
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    It sounds like condensation to me. Any oil in the water bottle or drop in coolant level? I would just give it an oil and filter change then see how it goes.
    Nov 2010
    BRECHIN
    well my water coolent bottle looks a little brown in colour is this oil? WHY ME! was i bad in a previous life!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by cont1204 View Post
    Like John said m8 alot of 3.2 owners have had this. Extension needs to be removed. Though personally how this fixes the problem escapes me but it does work.
    Gazza4
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Oil will appear like bubbles in the water and stick together because it's thicker. Coolant may just be a crappy brown colour anyway. Just in case and to give it a refresh, get the coolant changed with the oil and go from there. You'll then know what colour the coolant starts at and if there's oil getting in.
    Nov 2010
    BRECHIN
    not had it long enough to notice a drop in coolent. but will check and fill it up and go for a run. i cleaned all the mayo out the neck, there was nothing on the dipstick, just the amount in the filler neck really scared me!
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    It's because the extended neck sits in the cold air flow making any water that's not yet dispersed condensate in the neck.
    Don't worry about it. Twist the neck out and put the cap in the hole. I panicked too when mine did it. Short journeys make it worse, as does the cold air.
    Nov 2010
    BRECHIN
    thanks alot guys panick over for now! "clean under garments required" will remove the filler neck tonight and go for a run. gonna prob get a full oil and filter service shortly and get the coolent system flushed out. start clean! bet the garage gonna rob ma wallet!
  1. Sludge in header
    By GCusdin in forum Engine & Drivetrain
    Last Post: 4th December 2012, 20:18
  2. GSI creamy sludge in filler neck - normal?
    By coddy2200 in forum Engine & Drivetrain
    Last Post: 24th February 2011, 13:13
  3. Smoke and sludge from oil filler cap Vectra C 3.2 V6
    By bigmac22 in forum Engine & Drivetrain
    Last Post: 15th May 2010, 10:29
  4. Is this sludge?
    By sharpo in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2009, 06:15
  5. Engine Oil Sludge
    By MrBond in forum Engine & Drivetrain
    Last Post: 18th February 2008, 11:11
slug in oil filler cap vectra 3.2
