Results 1 to 10 of 17
Thread: error code
    redditch
    Default error code
    Got another error code P0620 and had only recently got this after changing my battery. Help please.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 74000
    P0620 Generator Control Circuit. Have you tried disconnecting the negative terminal, leaving it a minute or so and reconnecting it?
    redditch
    Yes tried that, i took the battery off again to see if i might of knocked something when i reconnected it but it all looked fine. Took the car for a spin on the duel carridgeway after i reconnected the battery and i lost all the power in my car the only thing thas was running was the engine so had no power steering the brake servo unit did not work basically anything that uses electric did not work.
    Luckily i managed to get the car home in one piece.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 74000
    Silly question but why did you change the battery? Do you have a multimeter tester?
    Jul 2009
    The Rift, Cardiff
    Sounds like possible alternator fault. Check the voltage of the batt with engine off and with engine running.
    Check the connections and earth points are secure.
    redditch
    Changed battery because i have got another fault code p0380 and some one on this site told me to try and change it as some times it can throw that type of error.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 74000
    Did you check voltage from the alternator first? Should be between 13.5v and 14.4v with the engine running, at the battery.
    redditch
    No i do not have a multimeter
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 74000
    Do you know anyone with one? Think you need to check the voltage first before doing anything else.
    redditch
    Got myself a multimeter so i am going to check the battery in the morning but i have never used a multimeter before so i will have a little play with it before hand. would it be correct that before the engine running the battery should pull about 12v and when the engine is running it should read 13.5v - 14.5v?
  1. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  2. error code 10 1 3 10
    By 6009tristanb in forum Engine & Drivetrain
    Last Post: 27th June 2011, 16:31
  3. error code
    By riauba in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2010, 21:43
  4. Error code help
    By Cat_J in forum Vectra C / Signum Troubleshooting
    Last Post: 18th January 2010, 17:48
