Results 1 to 10 of 26
Thread: FAN BLOWER NOT working at all....
    Dec 2010
    Bury St Edmunds
    Default FAN BLOWER NOT working at all....
    Hi everyone,
    Two days ago I have visit a car wash and back home, next day I`ve noticed that my fan blower not working on any speed Can someone help?
    I read some information here about resistor need to be fix but only if fan is working on speed 4 but not 1,2,3. Well, my fan is not working at all and I need some help from U guys. I just cleaned drain tube as it was all blocked in, I`ve also try to move a fan by hand and its moving quite good.
    Now I`am thinkin about having a go with resistor.
    I ring few of a auto-electricans around Bury St Edmunds but most of them are shut till first week of january Just one of them pick up the phone and told me that he need to check the fan motor first, and if resistor needs to be replaced he will charge me 75 quid max but he`s available to do this job on 4th of Jan
    Will be grateful for any advice. Thanks!
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 74000
    Im sure someone on here said the resistor is available from Maplins for pennys. Sure there is a how2 for this.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    yes it is maplin RA23A 82pence its easy to do as well
    Dec 2010
    Bury St Edmunds
    should be fine when I get the thermal fuse? Like I`ve said before... fan is not working at all on any speeds. :-/
    Dec 2010
    Bury St Edmunds
    So, I don`t need a new resistor? just need a thermal fuse? and must be exactly that one on maplin website?
    Aug 2010
    Luton
    Quote Originally Posted by Radek996 View Post
    no you can put a banana there but it wont work (sorry could not resist it)
    well its best to use as advised as thats the same as that has been removed and is proven not to burst in to flames and ruin your car
    Dec 2010
    Bury St Edmunds
    will give it a go before I will go to electricans :-/
    What alse should I try If that dosn`t help?(fuse replacing)
    Aug 2010
    Luton
    blue relay on left when you have glove box out
    Dec 2010
    Bury St Edmunds
    thx m8. Do I need SOLDERING IRON for fuse replacing?
    Aug 2010
    Luton
    no strip back a connector block and use that
  1. blower speed 4 not working. 1,2,3 OK
    By sunbeam in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2013, 15:55
  2. Heater blower stopped working
    By owb82 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2009, 18:24
  3. blower only working on number 4
    By damadom in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 17:28
  4. Heater blower has stopped working
    By Dave1971 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2008, 12:55
  5. Blower not working correctly
    By djr69uk in forum Electrical & ICE (including SatNav)
    Last Post: 30th April 2008, 16:22
