Thread: Electrical problem
    Apr 2008
    Denmark
    Default Electrical problem
    Hi there,
    I have a 2005 Vectra C with a strange problem.
    When pushing my fist down in a specific spot on the driver's seat, cabine blower stops, heated seats turns off and lumination of the blower's control panel and heated seats rollers goes out.
    Any idea? :-)
    Regular Member mxt's Avatar
    Nov 2010
    J17 M6 Sandbach, Cheshire.
    sounds like something is shorting (although with a high enough resistance not too blow the fuse)
    May 2007
    Norway
    Disconnect the cable to the heater in the seat. If all ok after this, you found the short/problem.
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    sounds a bit like a wire shorting out if you look under the seat all the wiring for the electric seat air bags etc is under there check none of the wiring is not split or become trapped in the seat track
    mine had a similar problem when i put the seat right back
    good luck
    Apr 2008
    Denmark
    Quote Originally Posted by Hirobofly View Post
    Oki, which cable is for the heater?
    Apr 2008
    Denmark
    Thumbs up
    Quote Originally Posted by crispy007 View Post
    good luck
    Sound like a great idea. I will remove the front seat and check it today :-)
    Apr 2008
    Denmark
    Quote Originally Posted by mxt View Post
    I think, you're right. I just cannot figure out, what can cause a short inside the driver's seat...
  1. Wiper Electrical Problem? (Not sticking or cold weather problem)
  2. electrical problem?
    By tjr2011 in forum Bodywork & Interior
    Last Post: 31st March 2012, 16:42
  3. Electrical problem, please help!!!!!
    By alancollier in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2010, 18:44
  4. Electrical Problem??
    By pilsbury in forum Engine & Drivetrain
    Last Post: 12th May 2009, 01:57
  5. electrical problem
    By gazman123 in forum Electrical & ICE (including SatNav)
    Last Post: 14th October 2008, 12:50
