Thread: Filling a battery ?
    Regular Member rickeys16v's Avatar
    N.Ireland ( Broughshane )
    Vehicle : 1.9 CDTI 150
    Trim : SRI
    Mileage : 46000
    Default Filling a battery ?
    i have just unscrewed the tops of my battery and 2 of the holes need filled up a bit what do i need to get is it distilled water
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    yes distilled water,bought from any motor factors.
    Aug 2010
    Derbyshire
    You still got one that needs topping up?
    Most I've had lately are the sealed one's, apart from the leisure battery on the caravan.
    Yes distilled water, your supposed to use that in steam irons as well, stops all that limescale build up.
    Mick
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Yes, distilled water, do NOT use tap water. I knew a young lad once did, despite being told not to. Had to get battery drained and refilled with fresh acid.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by Grumpy1954 View Post
    That seemed an ongoing fight while I was still in the mob.... young plonkers straight out of the factory were told the basics of 'first parading' a rover or MK/MJ, yet no-one pointed out to them 'top up with battery water' meant coming to the LAD for distilled/de-ionised water.
    LAD battery shop was always busy in every unit!
    12 Post(s)
    Quote Originally Posted by MickAP View Post
    Even the sealed ones can be topped up. They have a reservoir that tops the battery up by itself, but eventually that reservoir runs dry. If you can locate it then you can top it up to make the battery last longer. If you remove the label on top of the battery, sometimes you can see the outline of the removable cover to access the reservoir.
  1. filling up with cooking oil
    By montyfert in forum The 'Off Topic' room
    Last Post: 13th August 2012, 20:56
  2. Filling up soon can I put this
    By dannyjpuk in forum Vectra C / Signum Car Chat
    Last Post: 25th December 2011, 18:22
  3. DPF filling up too quick?
    By mally in forum Diesel Engine related
    Last Post: 30th August 2010, 21:15
  4. Filling insert
    By willoftoon in forum Styling
    Last Post: 20th June 2009, 00:52
  5. Filling Up
    By VauxVeteran in forum General Chat
    Last Post: 16th January 2008, 04:13
vectra c battery top up
