Thread: headlight washers??
    Regular Member vauxhall-john's Avatar
    fife, scotland
    Default headlight washers??
    need a wee bit help with my vectra its an sri cdti 150 nav, and its got the AFL headlamps with the light washer, the problem i have is they dont pop out when they are supposed to, when i switch on the headlights and pull the wiper stalk back to spray the windows the lights dont do it, i can manually pull them out but thats no any good,
    anybody have any ideas?
    cheers
    Regular Member benny's Avatar
    Feb 2006
    dudley
    i think they dont work bellow a certain temp .....
    fife, scotland
    that would make sense mate, alot of people said that they freeze up but i checked that they werent frozen,
    fife, scotland
    anybody else? it was 5 degrees outside today and they werent working still.....
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Do they spray ok when they're out? The jets are pushed out by the water pressure. Could be a blocked pipe.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Either that or the headlight pump may be knackered, it's a separate pump
    fife, scotland
    they dont spray at all, like you say john it could be the pump, nut hopefully just a blocked hose, are they easy to clean out??
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    11 Post(s)
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    My vec c sri as h/light washers, the washer only work when the headlights are on. Once they have worked they dont work again for up to 10 > 15 mins. after, what i have noticed is they dont spray straight away its normally 5 secs. or so after you operate the switch.....
    May 2007
    Norway
    There are some logic in the headlight-washers, to preserve the fluid. On mine they spray 1 sec after i press the stalker, and then it is a while again before they will activate if I use the washer for the windscreen often.
    Mine works even if -12 C outside.
    If they do not work at all, I would look at the pump, then pipes and spraybar.
    Popp the bumper off, and you'll have excellent access to troubleshoot.
    They don't spray every time, something like every 6th? but the lights need to be on as well.
    I guess you have tried this?
  1. Headlight washers don't pop out
    By throdo in forum Bodywork & Interior
    Last Post: 27th January 2012, 14:32
  2. Headlight washers
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2011, 08:25
  3. Headlight washers
    By rockh in forum Styling
    Last Post: 30th July 2009, 22:14
vactra c fl headlight wash
