Results 1 to 3 of 3
Thread: Parrot ck3100
    kent
    Default Parrot ck3100
    I'm trying to fit a parrot ck3100 in my vectra c. I have bought the adaptor harness and have a red and a yellow male wire and a red and a yellow female wire do I need to use these and if so how? Thanks Andi
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Hi
    You have a 2003 model do you need the adaptor harness?
    I fitted the parrot into wifes Siggy which is 53 plate Elite and that connect straight in as they are ISO connectors. The only additional connection you should need out of Parrot harness is the one identified as ignition which connects to the ciggy lighter supply which is normally the black cable going to ciggy lighter. You may need to swap the cables identified as ( ignition and 12 volt supply)
    There is s How2 for the installation.
    kent
    Cheers Keefy will check was told I would need adaptor but if I don't it would make life easier
  1. Parrot CK3100
    By blackviper90210 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd November 2012, 19:57
  2. Parrot CK3100
    By graham22vti in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2010, 19:31
  3. parrot ck3100
    By bigmac in forum Parts for sale
    Last Post: 17th January 2009, 23:56
  4. Parrot CK3100
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2009, 20:23
  5. Parrot CK3100
    By GARY3306 in forum Parts for sale
    Last Post: 1st August 2007, 23:18
